Toro Timemaster
RORY12553 Posted By RORY12553, Jun 13, 2013 at 10:27 AM
Thread Status:
  1. RORY12553
    RORY12553
    Minister of Fire 2.
    NULL
    Dec 12, 2011
    510
    30
    Loc:
    Southern NY
    I purchased a toro timemaster last year. Has a 30" deck and starts up easily. Only issue i really have is that grass seems to get clumped up around the bottom of the deck and I constantly have to clean it. I am using a bag most times too. The grass is dry also. Any suggestions?
  2. smokinj
    smokinj
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    15,981
    1,412
    Loc:
    Anderson, Indiana
    How's the deck look underneath?
  3. RORY12553
    RORY12553
    Minister of Fire 2.
    NULL
    Dec 12, 2011
    510
    30
    Loc:
    Southern NY
    As far as what? I read some reviews on it and some other people have the same issue with the grass getting clumped up around the blades. Grass I am cutting is not very long at all. Maybe I should clean it after every use? Possible to grass that might have been from prior cut is causing other grass to clump up on it? Basically bought this mower because I don't like a ride on mower and I also didn't think a commerical mower was necessary.
  4. smokinj
    smokinj
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    15,981
    1,412
    Loc:
    Anderson, Indiana
    I would clean under there really good. Then spray it down with a dry graphite spray underneath the deck and all the way through the shoot.
    Ashful likes this.
  5. Ashful
    Ashful
    Minister of Fire 2.
    NULL
    Mar 7, 2012
    8,895
    3,717
    Loc:
    Philadelphia
    smokinj likes this.
  6. RORY12553
    RORY12553
    Minister of Fire 2.
    NULL
    Dec 12, 2011
    510
    30
    Loc:
    Southern NY
    Paint isn't really there anymore. Didn't realize that would be the cause. This website is AWESOME!
  7. MasterMech
    MasterMech
    Guest 2.
    NULL
    Those machines are a brand new design from toro. 30"-33" residential walk-behinds are nothing new however. Troy-bilt, Sutech, and Billy goat all built decent examples. The new MTD/craftsman/cub cadet version is blasphemy to the original Troy-bilt design they copied.
    As far as the Timemaster is concerned, it's a two blade timed deck that was intended to mulch from what I see. I don't have any direct experience with that unit but I'm no stranger to that setup. I have a Deere LT150 with a Freedom 42 (similar deck setup but no bag or discharge, dedicated mulcher. ). Make sure your RPMs are set according to spec. Are you primarily side discharging with this unit with a side of bagging? If so I would look into the possibility of high lift blades for it. Also no matter what mode you use, don't try to cut more than about 2" off the grass. Most residential lawns do well cut at 2.75" or higher.
    Ashful and HittinSteel like this.
  8. Ashful
    Ashful
    Minister of Fire 2.
    NULL
    Mar 7, 2012
    8,895
    3,717
    Loc:
    Philadelphia
    Not sure that's the answer, but it can be a factor, and it's something anyone can fix themselves. MasterMech is the real expert here, I just bear the curse of mowing more grass than the average homeowner.
  9. fox9988
    fox9988
    Minister of Fire 2.
    NULL
    Jan 15, 2012
    616
    198
    Loc:
    NW Arkansas
    After a good coat of paint, try Fluid Film. Some of the pro's swear by it.
  10. RORY12553
    RORY12553
    Minister of Fire 2.
    NULL
    Dec 12, 2011
    510
    30
    Loc:
    Southern NY
    Where can i purchase fluid film?
  11. Ashful
    Ashful
    Minister of Fire 2.
    NULL
    Mar 7, 2012
    8,895
    3,717
    Loc:
    Philadelphia
Thread Status:
