I would like to use my 6-ton More-Power-Puller brand hand winch to drag some trees closer to buck them up. The trees fell across several deep ditches that would otherwise keep me from being able to get bucked up logs back to the truck. They are in a great position to winch them closer. I'd try to drag them with my truck but there is not enough room to get my truck aligned and close to do it.
It can be slow going with my hand winch as it basically moves it inch by inch as I pull back on the handle and the drum turns and the ratchet grabs another tooth on the gear. Is there some smarter way by using a rated pulley or something like this to increase the speed?
