I have seen this done on a few installs and we are planning on doing the same in our house.
A couple threads that show an example of what I'm talking about are here: https://www.hearth.com/econtent/index.php/forums/viewthread/42480/
https://www.hearth.com/econtent/index.php/forums/viewthread/43709/
We will be rear venting a Jotul F 500 Oslo into the opening of a solid masonry fireplace and chimney into the flue T. Aside from needing to provide an appropriate floor hearth, any combustible surfaces are well away from the rear vent connector and stove. We want to cover the opening with sheet metal until we remodel the room and reface everything with stone or tile.
We are planning on adding the Jotul rear heat shield to the stove for reduced rear clearances, but since it will be in front of a hollow, metal faced cavity, it seems moot. Anyway, I am on track with the chimney but the connection between the stove and the T are my concern. If I just use single wall pipe as the rear connector, my assumption is that I can just pass it right through the sheet metal with minimal play and apply a sealant and a decorative cover if needed. Basically, I've been eyeing the same procedure that the NFPA 211 requires for the damper opening to be sealed with sheet metal...it doesn't seem any different.
-Would a gap around the pipe be necessary?
-Am I better off to use a double wall rear vent connector?
It seems that no matter what, the sheet metal is going to nice and hot.
