    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. rickybamboo New Member
    in the cold
    I have a vermont castings radiance gas stove. The pilot wouldn't stay lit once I released the knob(had the gas off to it for the summer - just turned it back on) so I cleaned the tc/tp with an emery cloth. The pilot is lit now, but when I turn it to 'on' the pilot goes out. Any ideas?
    I'm a newbie - let me now if there is more info needed. Thanks for your help.
    #1
    Helpful Sponsor Ads!
  2. DAKSY Super Moderator
    Is it a B-vent unit?
    If it is, I encountered this symptom last winter...
    Check the wiring diagram - IF you have one.
    There's a thermodisk (spill switch) up near the top of the unit & under the removable grille.
    Remove the wires from either side of the t-disk & put a jumper wire between them.
    Does the unit work now?
    If so replace the t-disk. $20 maybe...
    If not, try replacing the wires to & from the t-disk...
    The sheathing gets brittle from being in the high heat environment at the top of the unit
    & may be shorting against the chassis somewhere...
    If it STILL doesn't work, try jumping the new wires to test the t-disk...
    Let us know how you make out...
  3. rickybamboo New Member
    in the cold
    wow....thanks for the quick reply.
    i've had a couple glasses of wine now (by the light of my pilot light) so will try your tips out in the morning. thanks again.
  4. Fsappo New Member
    Central NY
    To me, the fast answer sounds like a bad thermocouple. But I'm not too up on all the gas stuff
  5. Wood Heat Stoves Minister of Fire
    Nevada City, California
Thread Status:
