Q&A Venting a wood burning fireplace
QandA Posted By QandA, Dec 1, 2007 at 6:52 PM
Thread Status:
  1. QandA
    QandA
    New Member 2.
    NULL
    Staff Member
    Nov 27, 2012
    0
    6
    Question:
    I want to put a wood burning fireplace in my basement. I took out an old boiler which was vented to a masonry chimney approx. 8-10 inches in diameter. Can I use this old chimney which runs up through the walls and above the roof to vent a wood burning fireplace? If not, due you have any suggestions or alternatives?
    Thanks for your time and consideration.
    Answer:
    Chances are that you can use the chimney IF:
    you install a freestanding fireplace or wood stove which requires the same size or smaller diameter chimney.
    DO NOT TRY TO:
    Install a masonry fireplace or pre-fab zero clearance fireplace into this chimney
    ALSO: Make certain the chimney has a terra cotta (tile) liner...if not, you can line it with a stainless steel pipe.
    Hope that helps.
Thread Status:
