I was thinking the same thing but it would terminate about 12 feet under the deck.I would think that would be against code.
I don't think it can terminate under a deck. at least not here. the gasses will eat away at the wood anyway.[/q
I would check local codes. personally it would take a while to do any real damage, but if it ever burnt...As I am most familiar with Harman, but, I do believe their manual states that you have to be a minimum of 12" below a deck, so, therefore, yes you can, as long as you follow clearances.....
youre not likely to find it specifically addressed in the local codes, which is why you need to go to your manual. Which is where I went for the 12" clearance. The manual (most stoves are UL listed these days, and that listing technically trumps code, but you'll have to convince your local inspector of that)
By all means check local codes.
Most local codes amount to following the manufacturer's installation instructions for a listed appliance.
Further 12 feet is 12 times the distance usually listed in the clearances in this case. There are likely other things in that area that can cause problems like windows and doors that can be opened.
LW how's the stoves selling this year?
yes, some do. and then the manual says to check with the local codes. so who knows. if it is a concern the best thing to do is check with local codes. what they say goes. if they say follow the manual then so be it. the problem is, if something goes wrong, who is at fault, which may be the intention, I guess. lolLast I looked the code for this sort of stuff in Eastern Washington....refer to the owners manual.....
