Welcome to a new season, time to make sure everything is ready.
In the spring I cleaned up my stoves and basically forgot about them for the summer. Today I started making sure I was ready for a new season. Last season the fan on my VC Montpelier was a little noisy and required some oil about every 150 hours. I decided to see if anything could be done to keep it quiet a little longer this season. Pulled the unit apart to find two permanently lubed sleeve bearings. The problem was that the fiber that should have been soaked with oil was bone dry. It looked like it left the factory that way. The only oil on it was right near the shaft where I had been putting the occasional drop of 30 weight.
That said I have a couple of questions:
The fan unit is a 3,000 rpm FASCO centrifugal blower. Has anybody else seen one of these shipped with dry bearings? Vermont Castings has not returned my call yet.
Second question, has anybody replaced the OEM fan with the FASCO A212 or the similar Dayton unit? Both look like they will fit with a little sheet metal work. The shaft on my current unit is badly scored so I doubt I will ever get it to run quiet and I would prefer to try something different...
Thanx for any help or advice,
KaptJaq
KaptJaq
