Vermont Castings resolute acclaim
lctatlp Posted By lctatlp, Feb 26, 2013 at 6:25 PM
  1. lctatlp
    lctatlp
    Member 2.
    NULL
    Oct 6, 2011
    70
    10
    Loc:
    North Shore, MA
    I have a Resolute Acclaim - model 2490, about 12 years old or so. I've been running it for 3 winters now and my question is this.. The firebrick on the left side has deteriorated (I patched it back together when it was in 3 pieces with furnace cement a while back) and now is unrepairable. About 1/2 of the top of the brick is gone. I've been running it this way for a month. Am I doing any damage to the stove by not replacing the brick? When I was a kid we had a Lange that had no firebricks - so I'm also not sure of the purpose of the firebricks. Any help would be appreciated.
  2. Pallet Pete
    Pallet Pete
    Guest 2.
    NULL
    Firebrick is actually made from fire clay which is good at distributing heat as well as protecting your stove from warping. You probably are not hurting it from one brick but they are cheap at tsc or hardeware stores and it is easy to replace. Our old stoves that had no brick where prone to cracking on the sides and bottoms from the ash heating the plate and cast up to much. It was not a big problem but it did happen on occasion. Also I have noticed it helps burns by keeping more heat in the firebox allowing it to burn into ash better.
    Pete
  3. rkshed
    rkshed
    Feeling the Heat 2.
    NULL
    Jan 15, 2012
    269
    77
    Loc:
    NH
    Cheap enough to replace them and you will not have to worry any more. Aubuchon carries them for about $4.00 each.
    Our Garrison needed a few last year. I had to cut 2 so they would fit correctly but a mason blade on my circular saw took care of it.
    Easy stuff with solid benefits.
  4. lctatlp
    lctatlp
    Member 2.
    NULL
    Oct 6, 2011
    70
    10
    Loc:
    North Shore, MA
    The bottom grate on my stove has warped and possibly the side plate, when it hit the left side of the stove I can hear it clang just a bit!
    I guess an over fire? Although my stove has never been over 700 - as far as I know... Are these firebricks available for cheap money at hardware stores? They are not a rectangular brick but a contoured brick that looks specific to the resolute acclaim.
    I looked online and the cheapest I found is $50 for one damn firebrick!
  5. NSDave
    NSDave
    Member 2.
    NULL
    Dec 29, 2011
    114
    13
    Loc:
    Halifax NS Canada
    Bricks for the acclaim are $$$ I suppose you could use the $4 bricks and make them fit. IIRC the arch bricks were somewhere around $50 each plus shipping. I wouldn't run without them, as they protect the combustion package in the back which is even more expensive.
    This is why my acclaim is out in the garage collecting dust. If you were closer I'd offer you the bricks/parts from mine; coming to eastern canada anytime ?
  6. dougand3
    dougand3
    Minister of Fire 2.
    NULL
    Oct 16, 2008
    1,106
    223
    Loc:
    North Alabama
  7. lctatlp
    lctatlp
    Member 2.
    NULL
    Oct 6, 2011
    70
    10
    Loc:
    North Shore, MA
    Thanks guys for the info. I won't be in eastern Canada any time soon but maybe in the future to watch the Bruins beat up on the Canadians at the Bell Center. Thanks for the offer NSDave.
