Any ideas of how to weigh a wheelbarrow of split firewood short of buying an expensive industrial scale or weighing each piece separately?
I love Canadian engineers !Three bathroom scales?
Saskwoodcutter, great idea about using bathroom scales. I'm going to try that out. Thanks everyone for your suggestions.
TedyOH,, Jebatty in an old post in the Boiler Room describes using weight to determine how much wood to put in a wood gasification boiler to raise storage temperatures a set amount. His idea if I understand it correctly, is weight is a better determinate of wood BTU content than guessing at the btu content by the volume of wood being used, in my case roughly a wheelbarrow full per load. I'm burning a mixture of oak, locust, cedar, and various other unidentified hard and softwoods found here in the western portion of Virginia. It wouldn't matter if the load was mixed hard and soft wood as the total weight would be the measure.
My Tarm Solo Innova wood gasification boiler should ideally burn full out as it was designed to, and not idle, to avoid creating creosote. I have been undershooting and overshooting the amount of wood for each burn. Knowing the volume only of the wood is throwing me off. So hopefully I can add or subtract some splits to the wheel barrow load to get the right weight of wood to raise my thousand gallons of storage roughly 40 degrees. That is once I figure out the weight that does that trick, and allow for what is being used to directly heat the house while the boiler is burning and at the same time charging the storage tank.Thanks again all.
Mike
