What are the three buttons on the bottom of the control box? Englander 25 Insert
tonyiiiafl
42
Cape Cod, MA
On the bottom of the control panel are three buttons that seem to do nothing when pressed. What are they there for and which settings are normal? Just wondering!
What does the owners manual say? How about calling the company customer service?
Low Fuel Feed. Low Burn Air. Air on Temp. You can fine tune the pellet feed rate and combustion motor speed (CFM's) for the stove. On two auger stoves, it only works on heat settings 1 and 2. On single auger stoves, all through the heat settings. Air on Temp you should not adjust.
I see, thank you!
