+1 instructions on the package, but yes, I think I went up 18" (whatever the package said) and yes 2 bit sizes. The inner and outer pipe will expand and contract at different rates.Heard they were good.It will be on my vertical pipe about 3 ft from stove.Do i just drill horizontally into my double wall or should i angle it slightly so as not to fall out.Don't want that glowing thing fallin on the floor.Also what temps should i look for?I have read other posted reviews but everybody has a diff setup etc.3/16 through double and1/4 through outside i hear.
I like the SBI probe, it's similar to the Condar but has black and silver zones. Drill it straight horizontal, they have a magnet to hold it there. Instructions should be on the package.
I sure appreciate the replies.It is odd about the magnetic part though cause i have read that the magnetic stove top therm will drop when hot but there would be more heft with the megnetic not protruding into the pipe.Sure is nice to have the help we do here.
I have double wall pipe so prob magnetic would be useless,ya think i need a therm there at all?
Well the plus too all this,,,having a stove that drafts well. The opposite would be a real headache with smoke spillage. I noticed my first year with the Fireview,,,, it can be almost out of coals, move them to the front and the new load still takes right off. I'm all for that and watching that the flue temps don't run away,,,, to me it's like having a turbo start system,,,,, I'll take that! Most of the time once I see some good flames I can just leave the draft at one and once I'm reading 250 stove top,, I just close the bypass. I think that's a little easier on the stone then to have a quick blazing reload. Most of the time I'm just under or near 250 on a reload so it doesn't take long to get some new wood charred. Just being respectable of what the stone goes through.Engaging too early once in awhile shouldn't hurt the cat but it may stall on you or if you do it often it could become coated with creosote and plug up.
Flue probe is a good tool for a Woodstock stove. I have found while in the bypass flue temps can really get away from you if your not watching closely.
Thanks guys,can engaging the cat too early hurt it or it just wont burn clean? Also i noticed ya have to be quick to turn the stove down when reloading on a bed of hot coals.I have warmed the flue up pretty fast and heard it snapping and burned some of that new smell off of the pipe because i haven't had a fire yet over 400 and i just cleaned my chimney.It's just the sound of the pipe expanding.What temp is too hot for a flu temp? I also heard that the difference between stovetop and flue is around 200.Don't quote me on that last part.
