What do you do with splits that are too long?
petehouk
18
Ann Arbor, MI
I have some splits that are just too long. I guess I could probably shoe-horn them into my stove on a crazy angle, but that makes it really tough to fit other pieces in at the same time. And there's no way to load the stove up for night time with one wedged in at an angle.
So I am thinking about cutting some of the longest pieces. A hand saw sounds tedious. A chain saw would be faster, but how to hold the piece while cutting?
Any ideas?
Thanks
Pete
Any ideas?
Thanks
Pete
A chopsaw is what a lot of guys on here use. I prefer my chainsaw and two saw horses.
If I have a number of them to shorten a bit, I'll use my hydraulic splitter as a "vise" to hold the splits sideways across the beam, them trim them down with a chain saw. Rick
Give them to my father-in-law.
fv
Make a saw buck.
Not mine..I borrowed the pic.
know many are going to say its not safe, but i put my foot on it to hold it while cutting it in half with my chain saw. been doing it for years. or, i'lll sometimes set it on the chopping block. just have to be very very careful.
cass
^^a lot of folks ,including Me do just that . If I have more than a few it's off to the chop saw with them .
Sounds like a great time to measure your firebox and cut accordingly for a N/S burn.
fossil..im trying to picture what u are saying..it has me intrigued ....maybe a picture would help
HotCoals said:
Make a saw buck.
Thats cool...I need to make one!
I don't have any splits that are too long. After I did the short stroke mod on my splitter, if the round is too long it won't fit in the splitter so no worries that it won't fit in the stove.
That said, I once got 3 cord of split seasoned Ash for free and had to cut 4 inches off every split so it would fit in my stove. My two sons were still living with us at the time so I grabbed the Sawzall and put them to work. I tried my 10" chop saw but most of the splits were too thick for the depth of cut. A 12" prolly would have worked.
I've stacked a big pile and ran the chain saw thru then.
I set aside for campfire wood.
Oregon Bigfoot.
Well, here's the basic concept.
Does anyone sell sawbucks? I need one seems like a handy must have commodity,along with all the other woodburning paraphernalia.
Lots of places sell metal ones but I hate to see metal anywhere near a chainsaw. You should see all the saw marks on my sawbuck. Most folk just make their own out of wood.
Several years ago some folks mentioned that they had a device call the Chainsaw Buddy. I think it might work for this application. In their video they show him cutting up some shorties.
http://www.chainsawbuddy.com/index.htm
fossil thanks..thats pretty nice idea...i have an electric splitter that wont stay forward like that....sure wish it would though
I have a mark on my sprocket cover that is 20 inches from the tip of the saw. My stove is 22 inches wide. I eyeball every cut before I make it using the chainsaw as a guideline.
So, all my splits are really close to the same, and desired length. My buddy help me cut up a downed oak one time and nearly everything he cut was three or four inches too long so I had to cut them down when I got them home. I don't have a saw buck. I just (very carefully) put one end of the round over another split on the ground and cut off those extra inches. Then I throw the chunks in a pile to be burned also.
firecracker_77 said:
HotCoals said:
Make a saw buck.
That's pretty cool. Any plans or can I purchase somewhere?
use two pallets and strip two ot three slats off of each side at one end, lean them up against each other drill holes through both and insert carriage bolts
Reactions: onetracker
I do this as well - it has worked okay for me. If I have just a couple of pieces that are too long then it's for the campfire.
I also use my foot to hold a piece in place - just be careful and wear steel toe boots!
Um, cut them shorter...
I made this box for cutting wood shorter. It works like a giant miter box.
Just fill it up and run the chainsaw down the middle. Works great.
I have a chainsaw buddy (got it from Baileys) It works best for cutting long smaller branches.
Some splits may be a bit too big for it.
