ControlFreak said:
Dr. Drew:
There is a huge difference. Relative to cat vs non-cat, just keep this in mind: A cat stove is a much more complex stove to operate, because you will be responsible to identify the proper time to close the bypass damper to direct the exhaust through the cat, and for ensuring that the cat stays lit. Also the final combustion takes place behind "closed doors" in the catalytic element rather than in the main firebox. That is, if you run the stove on its lowest setting, you will have little or no fire in the main firebox while the catalytic combustor burns up all the smoke. This means that the fire that you observe through the glass will be more active with a non cat stove. The glass with a cat stove will tend to get covered in creosote, while a non cat will tend to have clean glass. Given that you are a new wood burner, get the non cat stove. I consider the cat stoves to be for those who have advanced knowledge of wood burning and are willing to go through the extra effort required to make them run well.
Dan
Wow
!! I can tell Dan has heard some stories....that just are not true. Sorry Dan, with all due respect, I have to disagree pretty strongly with your information as I see this sort of thing every now and then. Most usually by someone who sells stoves without cats.
When we were in the market for a new stove a couple years ago I too had heard stories about those danged cat stoves and without even checking further, we had our minds made up to stay away from those things. However, long story short is that we ended up actually buying a cat stove.....and have not been a bit sorry for it. In fact, if I were to buy another stove today it would look at another cat stove.
1.
Cat stove is complex to operate. Right... They are so complex that a child or even my wife can easily overcome this so-called complexity. Please allow me to explain:
Whenever you load any stove with wood and get the fire going, you have the draft set on full, no matter what kind of stove you have. Before you open the firebox door, you open the draft full.
Actually, most times you already have that draft on full open to finish off the last load you put in. So, when we go to load our stove, it really amounts to moving one lever from the up position to the down position. Excuse me, is this complex?
After loading the stove, one leaves the draft open to insure the wood gets started burning good before partially closing the draft. Now let's add the complexity of a cat stove. When turning down the draft, you at the same time move that little lever (which is right next to the draft lever on ours) from down to up. Excuse me, is this complex?
2.
Ensure the cat stays lit? I've never heard of that one! Once that little lever gets moved from the down to the up position, it does not get touched again until it is time to reload the stove.
"Also the final combustion takes place behind "closed doors" in the catalytic element rather than in the main firebox. That is, if you run the stove on its lowest setting, you will have little or no fire in the main firebox while the catalytic combustor burns up all the smoke. This means that the fire that you observe through the glass will be more active with a non cat stove."
You are correct in that the final combustion takes place in the cat, but no closed doors. If you run the stove on its lowest setting, that does not necessarily mean you won't have fire in the main firebox. On the contrary, that can be when you get the best flame! Sometimes you will not get flame on a low setting for sure, but that need not be. If you want to watch flame, there is no problem at all. We have our stove both ways. I can dial down to not get any flame....but that will not stay that way for long as the secondary combustion does kick in and give a beautiful rolling flame. Or I can set the draft so there is a good flame in the firebox for viewing and extra heat. The nice thing is I have a choice in which way I want it to burn.
Now this one really gets me.....
3. "The glass with a cat stove will tend to get covered in creosote, while a non cat will tend to have clean glass."
Whoa! I'm not sure how you got this information but I can assure you it is entirely untrue. In fact, with a cat stove your glass will probably stay cleaner!
Our glass did turn black once. That is when the stove was new and we were doing the burn-in. After a good fire it cleaned itself and we have not gotten any black or creosote on our glass. None. Zilch. Nada.
4.
"Given that you are a new wood burner, get the non cat stove. I consider the cat stoves to be for those who have advanced knowledge of wood burning and are willing to go through the extra effort required to make them run well."
That advanced knowledge boils down to turning that little lever one direction or the other. No other "extra effort" is required, except for cleaning the cat occasionally.
So here is one extra step with the cat stove. Usually twice during the winter we'll have a warm day or two. Yesterday was our warm day (44 degrees for high) so we almost let the stove go out. Good time to check the cat. Here is what I did:
Open the top door of the stove. With gloves on, reach in and lift out the cat. (one handed). Take cat outside and with an old paint brush lightly brush off white fly ash. Set cat back in stove, close lid. Time required? I was a little slow yesterday and it took me around 3 minutes if I remember right. Usually only 2. Hard to to? No. My wife can do it and so could a child. After closing the lid, a couple pieces of kindling got the fire going without the help of a match.
More in next post as apparently I've used up the space allowed.
