What kind of Lubricant for the versa grate shaft?
I use high-temp anti seize, available at auto parts stores. A can will last you forever. Don't forget to lube the front bushing, also, right near the igniter. You can also use it on the cam.
One can get it in very small tubes. Great on screws and bolts that need to come on and off that are around heat. Door hinges too.
Can lasts forever is a overstatement:) This can is well over twenty years old
Time to replace it Bio...... Looks worse than last time. It comes in a tube now btw.
Lottie C5-A copper based high temp anti seize -30 to 1800 deg F. Can find it on Amazon.
Walmart, O'riley's, Autozone too.
