I agree on the chimney liner thing. I'm still learning while keeping down my initial costs. I'm going to plan on having the chimney cleaned after about 10-15 insert burning days. I'm only 3 days in right now.
I'm pretty sure a huge problem I have right now is a cord of green wood. It's time to go buy some more wood racks and try to find drier wood. I'm shutting down for a few days while searching for good wood. I've got a few trash cans of lumber scraps I've been tossing in to try and keep temps up with this wood, but that's just creating wild swings in temperature. That's one reason for starting this post. Now I see that I'd be best to keep my stove temps under 700.
Because this all is so time-consuming, I'm basically shutting down my burning for a while. I want to:
1) search for drier woods
2) Get a good stove thermometer. Any recommendations? It seems I was getting best (hottest) readings on the glass. Can I put a magnetic thermometer on the glass with a block of metal on the back? There's not a lot of firebox metal exposed on the front of my stove. So my opinion is that the glass would provide best readings.
3) Maybe get a moisture meter for my wood. It looks like you need to split each piece to get an accurate reading though, huh? Maybe this is not worth the trouble.
Oh... the liner thing: I've researched this quite a bit. My stove recommends/requires an 8" liner. Since I don't want to destroy my regular fireplace damper (because I'd like to be able to switch back to an open fireplace)... I'd need to go through the damper with an 8" oval (I think this was 5"x10-11" last time I checked) which barely squeezes through my ~5" damper. An 8" round definitely won't get through. Also, the 8" oval is too wide to get all the way up to the straight 13"x13" clay liner. The sides hit brick on the way out of the section that connects the firebox to the straight liner. This section goes up at a slight angle and gets narrower at the top. About 4 feet of 8" oval, and it's touching brick. All of this is coming up from the bottom of course. I should be able to drop an 8" round (or oval) all the way from the top down the clay liner, but only an 8" round would fit all the way down to the fireplace damper. The problem would be getting the 8" round-to-oval converter. I won't be able to get the adapter down from the top because the 10-11" width of oval will be too wide to get through that section at the top of the narrowing smoke chamber. I also won't be able to get it up from the bottom because the damper is only 5". I assume my best bet would be to cut the adapter to a minumum possible size and bend it through, and then try to re-bend it back into shape. Maybe I could cut the adapter, and try to put it back together? Or just have a special adapter fabricated? Or maybe use 6-7 inch liner instead... maybe just for that bottom portion?
I'd hoped to get all this done before it got cold... but there are lots of things I wanted to get done that I have not. I'm happy to have an insert that burns well with the little time and money I've invested.
I agree... I don't want to burn my house down... So I'm not going to burn too much without a chimney inspection soon. I'm burning and learning.
One thing I wish I could do with this old '80s stove that I cant: Let in enough air to keep this green wood burning hot. If I open the ash pan the turbulent air seems to get the fire going, but since there's no automatic regulator on that, I need to close the ash pan opening eventually. Then there's not enough air through the thermomstatically controlled inlet to keep the fire hot. So I'm out of business until I get drier wood. Too bad I put last year's wood on the bottom of the pile somewhere. Oops!
