What to look for when buying a wood burning stove...
FyreBug
776
Kitchener, Ontario
Hi everyone, I thought I’d start a thread for those that come on this board for advice when buying a wood stove. This would be a repository of all the communal wisdom in short form we can offer first timers or others who are confused by what to look for. This would not be a discussion of a particular brand vs another, but rather how to get the most value for the budget. If we have a consensus we may edit a final draft and make it a ‘Sticky’.
1) Determine what kind of user you are: While there’s all sort of information about Square footage & performance available on this forum & from dealers; you must first determine what kind of wood burning user you are/will become:
a.Emergency use: Your stove is mainly a convenience as a backup appliance. Worst case scenario, you can heat the house, boil some water and cook a can of beans. You will be looking for a smaller inexpensive unit. Mobile home users also fits this category.
b. Ambiance seeker: You & your family enjoy entertaining and want a nice looking unit when you have friends over. Heat output is a secondary consideration. Since you and your better half will likely be making babies in front of this you are likely looking for a medium size stove with a large glass viewing area such as a bay window. Since look is a prime consideration you will probably be willing to spend extra for cast iron, soap stone or European look.
c. Serious heater: You have a chainsaw, a woodlot, a maul and know how to use them. At the very least you have access to inexpensive wood. You want your stove to be the primary heat or seriously cut down on your utilities expenses. You will be looking for a large stove with long burn time.
d. While these are gross generalizations and there may be overlap in what you are looking for it at least help you to determine what you are after.
2) Where to buy:
a. Hearth Specialty Stores: These are folks that specialize in wood burning and they know their stuff. They install & service what they sell. They have a large selection from various manufacturers so are able to quote according to your budget. This works well for people who don’t want to lug a 500Lbs stove around and let someone else do the install.
b. Hardware Stores: They typically carry lower priced units with an ‘all black’ look. Level of knowledge and support is limited and these stores are geared for the DIY crowd. Need a pick up truck.
c. Internet re-sellers: Since they do not operate out of brick & mortar stores their main approach is low cost. If you don’t mind having a stove shipped and land on your driveway to save some money this is something to look at. Level of service is typically minimal.
3) Look: Unless for a man-cave make sure to take your better half along. As the sayin’ goes “if Mama aint’ happy, aint’ nobody happy!”
4) Catalytic stoves vs. Secondary Burn Stoves: Most stoves use a ‘secondary combustion’ to burn the smoke. A smaller proportion of stoves use a catalytic converter to reduce emissions. There are many posts on this forum discussing the pros & cons of either. You may want to do a search on this. But suffice it to say ‘Cat’ stoves are typically more expensive than the non-cat, they have a longer burn time due to lower burn temperature. Word of caution: Cat stove requires a user who knows how to use one properly otherwise you may damage the catalyst ($$$). Again do some research first.
5) Type:
a. Plate steel: By far the most popular and least expensive way to go. Look for the thickest plate possible. Thicker = better heat retention & solid construction.
b. Cast Iron: Retains heat longer due to thicker material. Now come in glazed colors & looks. More expensive than Plate Steel.
c. Stone type: Soapstone & other material to get a specific ‘look’. Most expensive units.
6) Baffle: The baffle is designed to hold the heat down for the secondary combustion tube to do their work. The baffle can be made of the following materials:
a. Bricks: least expensive material. Have to be replaced on a regular basis. Easy to replace.
b. Vermiculite: Typically comes in 3 density: light, medium & heavy. Has a heat resistance factor of up to 1,200f. Depending on density has to be replaced from time to time. Degrades over time. Can warp if overheated. Easy to replace.
c. Steel baffle: No maintenance & long lasting. Can warp & crack over time & if overfired. Next to impossible to replace.
d. ‘C’ Cast: This is a ceramic composite cast material typically found on better units. It’s more expensive but has a heat factor of close to 3,000f. Lasts a long time and helps the performance of the unit. It is not brittle and can take some abuse.
7) Bricks: Used to line the firebox & hold some heat in.
a. Low porosity: These are light duty bricks. Easy to identify, they are light & bumpy. Have to be replaced more often.
b. Refractory bricks: These are found in furnace & better quality stoves. You can tell them apart by their smooth surface. They are quite heavy & last a long time. Better heat retention.
8) Door Latch: This may not seem like a big deal but this tells a lot about the quality of construction. Lesser stoves will have a bent rod as a latch, whereas better quality one will have an adjustable mechanism such as a roller for a smooth operation. The adjustment also allows you to tighten the door.
9) Warranty: You will typically find better warranties on stove brands available through Hearth Specialty stores. Items to look for on Warranty are the glass, stainless steel tubes, baffles & blower. Obviously, the longer the warranty on these components the better. Lesser warranties are typically from 1 to 5 years whereas ‘Limited Lifetime’ can be found by some manufacturers. Word of caution: some manufacturers will honor the warranty only if you have registered it within 30 days of purchase.
Part #2
10) Burn Time: Unfortunately no one regulates the definition of what is a ‘burn time’. It is up to each manufacturer to come up with their own definition. You may hear some wild numbers out there but a good definition is when you have started a good fire until there is enough coals left to re-ignite a stick of wood. You typically want an overnight burn. It also depends on your draft, type of wood etc... In case of doubt check the forums for a particular model.
11) Efficiency: If your stove is 80% efficient it means 20% of the heat is going up the chimney. The higher the efficiency the more desirable. The EPA label is not a good source of information for the efficiency since they test with small quantities of soft wood (Douglas Fir)
12) BTU: For the same reason as above the BTU rating on the EPA label is not accurate. Manufacturers will list BTU ratings based on seasoned hardwood. Remember EPA is primarily concerned with emissions, not efficiency and BTU output.
13) Size Cu ft: Manufacturers list their firebox size in Cubic feet to give an idea of how much wood can fit. Small stoves are about 1 to 2.0 cu ft, medium 2.0 to 2.5 & large 2.5 to 3 or more. Word of caution: some manufacturers list their size without brick therefore making it sound bigger than it is.
14) North South Vs East West configuration: Most stove allows you to place the wood ‘width wise’ or East/West. However, many serious wood burner like the deeper boxes North/South.
15) Nice to have: Blowers come standard on some models but are reasonably priced if you purchase after the fact. They help in distributing heat around you stove, look for a stove that allows adding a thermocouple option – turns blower on & off automatically.
a. Peds vs. Legs are a question of taste but pedestals allows for a larger ash pan.
b. Customizable look such as a door overlay, air mate & others can make a difference for some who would like to improve or change the look of their unit down the road.
I hope this helps. I know this is lengthy so any offer to edit is welcomed. We’ll try to make it as unbiased as possible.
Put it in the hearth.com wiki so people can edit as needed without a thread becoming nine miles long, I know I could add a quarter mile to it right now addressing some of your points.
As it is it is just going to become a cat-vs-non cat, steel-vs-cast-vs-rock, stainless baffle-vs-brick baffle-vs-ceramic fiber board baffle-vs-ceramic baffle thread that will go on forever and end up getting closed because it will get heated. Not good heated.
Thanks Brother Bart, I'll try to figure out how to do the Wiki thing tomorrow.
As regards the Lopi bricks, I looked at the video and yes we use the same brick but note the sales rep stated in the video "should last the life of the stove". While it is true you should get a long life out of these bricks, how do do define the life of the stove? Depends on many things.
We use these bricks inside furnaces where the temperature gets higher and people tend to burn a whole lot more wood. So better be conservative and state they last a long time. Everything else is a sales pitch. I am a salesman so I should know.
Most if not all manufacturers including Lopi & Osburn warranty the bricks for one year.
I can't agree with #8. After having issues with adjustable stove doors in the past the one piece, bent rod through the door held a lot of weight when I purchased my country brand stove. Simple design with less movable parts to wear and loosen.
This may not be as much of a problem on quality stoves but to say that an adjustable door is sign of quality is wrong. Lots of cheap stoves have adjustable doors with two or more pieces held together with nuts and or cotter pins that can work loose , become stuck, or need adjusting during a 24/7 burn. I can also tighten the door seal of my stove within seconds using a 12" adjustable wrench although I assume it will be a while, if ever I need to since as the gasket wears I can just turn the handle down more for a tight seal.
Lotta great considerations here IMHO, and alot of information I didn't even know when I bought my stove (and had spent 2-3 weeks surfing these forums and starting threads beforehand).
I don't know what type of baffle my Lopi Republic 1750 insert uses, and I'm hoping for ceramic now :)
One of the interesting things I personally discovered, applying to inserts at least, is that the price difference between a "generic brand" and a "high-end brand" on MID SIZED inserts is really not that substantial. In my case, I was looking at things like Northern Tool and seeing $1000 inserts of similar size. But one I added in the surround trim, blower, and shipping it was the same cost as my Lopi unit...and the Lopi was a much better recognized and renowned brand - however, the only reason the price was pretty much the same was because Lopi introduced an "economy line", the Republic unit. Prior to that, their same-sized unit was the only alternative and was $500 more.
My brother in law is a real saver and recommended Northern Tool/Harbor Freight since he was able to drop a stove for $650+liner into his 1400 square foot home and save alot of money. However, once I did an analysis with him on an insert from those same sources vs. the Lopi I was looking at, even he recommended the latter for the subjective benefits like look, fit and finish, quality, and warranty.
Joe
And I could probably add another quarter mile to it behind Brother Bart's just addressing some of your points. Then when both of us were done, Jake would probably add another mile to it....
One more thing, if you are intending to make a sticky or add to wiki, do you really need things like, "Since you and your better half will likely be making babies in front of this..." in your posts? Yes, many will get a chuckle from it but at the same time many will find this downright disgusting and will then write off your entire post.
Rule #1 is: Offend the least amount of folks you can. There will always be some that scoff and some that will be offended but you must do your best no matter what.
Dennis,
I was mulling over what you just said and then I read your signature saying, "Ornery wife ", and had a good chuckle. The irony was abounding :)
Most of points are good, but need a lot more detailing and in some cases like soapstone stoves, a whole lot more information. There are also some bad assumptions or just plain errors.For example, I have not heard Lopi owners complaining about frequent replacement of baffle bricks. As written it feels more like an insight into how a steel stove salesperson sees the customer, but with some tweaking, it could prove useful to some folks.
Joe, who am I possibly offending?
I have a Lopi Endeaver that has the brick baffle above the burn tubes, I thought that the brick was one of the better baffles especially over the blanket type, guess I was wrong.
Nah. That brick baffle is just fine.
People who view unfavorably anything that looks like a repeat of female stereotypes ? Or "wife" stereotypes?
I'm not saying your profile is offending, but that the original comment seemed so unoffensive (to me) that, whe you pointed it out as possibly offensive and I felt the same way about your profile, I felt it was ironic.
Again though, it's purely a reaction to people attempting to never offend anyone.
Point 2 needs a D - bought used.
You can pick up perfectly serviceable units off craigslist or whatever else from people who are moving, estate sales, whatever. This is how I got mine.
However this is not suggested for anyone not interested in doing a refurb. Despite getting my stove for 70% off, the catalytic and refractory are basically hosed. The refractory is repairable with a bit of elbow greese but the catalytic has a hole in it. If you're willing to put the work in it, there's deals to be had.
What about convection vs. radiant heat ??
If I missed that one I apologize, I just split about 2 cord for next year.....o yea, about 5 BL's.
Stay warm!
-Mike
Stay warm!
-Mike
Good point. There is a lot to cover here. Lots of things missed like varying flue requirements, clearances, hearth requirements, etc. For some people, ash pans, trim options, short leg kits,etc. are important. Inserts have their own set of requirements too.
I think Craig has provided broad coverage in his articles.
https://www.hearth.com/econtent/index.php/articles/choosing_a_wood_stove
https://www.hearth.com/econtent/index.php/articles/wood_stove_intro
https://www.hearth.com/econtent/index.php/articles/insert_intro
Could not agree more, I have seen adjustable doors on cheap stoves and the bent rod on the very best stoves...give me the bent rod anyday, never had or seen a problem with them.
I thought the efficiency numbers offered by manufacturers referred to combustion efficiency, not thermal efficiency...in other words, what percentage of the fuel was completely burned/oxidized, not how efficiently the stove captured the heat from the exhaust gases/vapors...
Am I wrong?
A good idea and a good start . . . but needs some tweaking . . . and some more points need to be added.
Here are a few of my ideas/suggestions:
Emergency use . . . If I bought a stove primarily for emergency use to keep myself, my family and my pipes from freezing I may want an inexpensive stove . . . but the size would still be appropriate to the size of the home. The last thing I would want to do is buy an under-sized stove and find that is is not up to the one task, the one reason I bought the stove . . . i.e. keeping me warm and keeping my pipes from freezing. Size is important here.
Mobile home use . . . while a mobile home owner may need a smaller stove for their smaller home, they may not necessarily want to buy a cheaper stove . . . they may wish to buy a higher priced model . . . although granted . . . around here I would suspect that most folks in mobile homes would also want to buy cheaper stoves.
Serious heater . . . again size is important . . . saying that a serious heater needs a large stove does not make sense to me . . . what if I lived in a 700 square foot home . . . should I buy a large stove simply because I plan to heat 24/7? I would maintain that sizing a stove is the most important step for any user . . . and I agree that one should take the figures in the brochures and on the websites with a liberal grain of salt . . . and that's why I typically suggest sizing a stove to the home and going one step larger. Incidentally, in my fictional wooduser above . . . I would probably suggest going with a stove with a cat if they had a small space and wanted long burns.
On-line sales . . . while not specifically addressed other than to mention resellers I think it would be a disservice to The Chimney Sweep, Mike and the crew at Woodstock who frequent these pages to say that on-line dealers or re-sellers do not offer a high level of support and service. While I suspect Mike wouldn't personally drive up to install or service an Englander stove here in Maine I do know from owners of Englanders (and Woodstocks for that matter) that the level of on-line and telephone support is outstanding in some of these cases.
Blowers . . . blowers may be nice to have . . . or they may not be necessary. Like ash pans, legs vs. pedestals, etc. it is often an option that may or may not be nice or necessary. I know in my case the dealer suggested I try the stove without buying the blower . . . and I'm happy to say my cheap floor fan from
Walmart works pretty well in keeping my entire home heated . . . other folks may say that their blower on the stove is the best thing since sliced bread . . . I think it's often a matter of personal preference.
Legs vs. Pedestals . . . You can have legs and not have to sacrifice not having an ash pan. In my own case I not only have legs and an ash pan, but it is actually quite large and very functional.
Again, a good start . . . just needs a bit of tweaking and some additions.
Wow! My wife certainly is no stereotype for sure.....but she is ornery. Actually, there is no offense and she even laughs at it and has never taken offense just like I take no offense at some of the names she calls me.
Also one must bear in mind that no matter what is said or written there can be someone else who takes offense. The old saying is very true: When you try to please everyone, you end up pleasing practically nobody.
The ornery one gives her blessing.
Thanks for all the suggestions. I'll tweak the post some and put it in Wiki. On #8 re. the latch system... I have seen some cheap stoves with bent rod that just 'doesnt feel right' when you close the door. Maybe that point should just mention something about the overall quality of construction such as the latch etc...
Also since this is designed for someone who is new to wood burning or is looking for generic advice when buying a stove we should keep each point brief and to the point. We dont want to start a debate over Cat vs Non-Cat. Maybe for each point we can add a list to the forum where a specific point is discussed at length. for ex. for more info on cat vs non cat please follow this link.
On the baby making pun, the point is well taken.
On the baffle questions. I'll create another post to discuss the differences.
But... Heavy Clay (refractory bricks) are just fine as a baffle. Along with all the other materials mentioned. Lighter pumice bricks will degrade faster over time. The point is... Which one give you the longest life and best performance? Since we're doing discussing comparative 'value', perceived or real this is a valid point.
