Hello- Can anyone tell me where to find a heat output rotary control for my stove? Pre-Lennox Advantage II with simple controls-"heat output" and "blower speed" dials, auger on, and start button. It looks like someone replaced the original heat output with a seven-setting one (I assume there's supposed to be just five?) Setting one runs the fan at a fast speed with no auger feed, 2 seems to run too fast to be called pilot mode, and needs the damper to be open slightly more than the other settings to avoid pile-up. 3-6 runs as I suppose you would expect 2-5 to work with the original rheostat. Seven runs the combustion fan fast, though not as fast as setting one, without auger feed. I wasn't able to get any useful info from a digital multimeter, except that the motor is fine. I haven't tried an analog one yet.
The stove came with the house we recently bought, so I don't know any of the history. It's been thoroughly cleaned.
Thanks for any input.
