I have a Whitfield Advantage WP2 stove from 1994 so I believe that it is the II-T model.
I have been having the following problem and I am trying to determine what replacement parts to try.
When the stove is full, the auger stops turning. If I have a small amount of pellets in the stove it works OK.
I am guessing that the auger bushing is wearing out or the motor is getting weak. From what I understand, the motor won't simply get weak. It will either turn the auger or it won't. SO if I go with trial-and-error, I might as well try the cheapest repair first.
I am having trouble figuring out what replacement parts to order.
The brass bushing that is on the end of the auger (the end that is closest to the motor) that slips into the end plate ... is it called the Auger Oilite Bushing? I have attached a picture of an auger to this post.
http://woodheatstoves.com/bushingaugeroilite-12per-p-2846.html
Also, what exactly is the Auger End Plate (w/nylatron bushing). Is this a replacement for the brass Oilite Bushing?
http://woodheatstoves.com/flangeaugeriit-p-2935.html
Would this be the plate that is located at the end of the auger that the brass bushing slips into, located between the brass bushing and the auger collar (with set screw)?
Cheers.
Cheers.
