Did you know your wood stove was NOT made for over night burns?
Agree? Disagree?
Totally. And the wood and operator.Depends on the stove.
Too bad, the Super can go up to 16 hrs between burns.I helped my neighbor install a Super 27 this year and he still won’t load it up full or burn it overnight. Just throws a couple sticks in at a time and lets it burn out before bed. In the morning he wakes up with his house in the mid 50’s! Brrr!
The point is the generalization - taking examples he sees and applying them to all stoves.Well.... it is YouTube. Where anyone can post a video about anything. And then the trolls descend in the comment section....
Cough....
Okay, got the YouTube commentary out of the way. Now to the reality. Three (3) points:
1) He may be right. For many stove and many chimneys. That many people still use as a professional sweep is maybe a bit tired of seeing poor wood stove use. As already said, @kborndale, the stove matters. Modern stoves will never allow someone to "smolder" dry combustibles as there often in built corrections to prevent this. One of my stoves has two adjustable air inlets and one fixed inlets to prevent me from causing creosote issues. But he has to deal with many, many, many not modern stove and many, many, many people who have no clue about wood burning. I can not blame him for going for the lowest common denominator.
2) But also there is a chimney. After many years of wood burning, we torn down or masonry chimneys and installed insulated chimneys. And, yes, chimneys also matter. Before we tore down the chimney we were racking out a lot at the bottom. After the new chimneys, hardly much at all. Insulated chimney do help move the smoke out of the flue. So they do not precipitate on cold flue walls.
3) Unseasoned wood. You can have the best, most modern stove. The best. most modern chimney. But if you burn unseasoned wood, you are in trouble. Sadly, too many blame the stove, when the real problem is inferior wood. I watched recently one "YouTube" video were the person said his full round wood was dry because it has been around for years, and yet he complained about how his stove was not giving off much heat and smoking a lot (the "suggestions" from his "followers" how to fix it ranged from good to nightmarish). As we all know, full round logs can hold a lot of moisture. But this guy did not get that message (or bothered to get a moisture meter). I suggested he go here to get good advice, but my message was never posted ... I guess that YouTube fear or external link advice (and yesterday my YouTube account was blocked and did not allow me to log in...... )
Sadly, phones and tablets are not friendly to forums. Very sad.I quoted you verbatim:
"Modern stoves will never allow someone to "smolder" dry combustibles as there often in built corrections to prevent this."
(edit: I added the quotation marks above)
And the quoting function on this website does not work for me on my laptop or my phone - so you can complain to the webmaster.
And: Bless you.
Disturbing indeed and dysfunctional info for new wood burners.The fact is the guy making the video is in charge of training a pretty large crew of guys in his business and is vice president of the largest training organization in our industry. And the info he gave is simply incomplete for old stoves and dead wrong for modern ones. Each of those people he trains is then going to relay that information on to thousands of customers. And if they follow it at best they will be wasting a large percentage of their heat out the chimney. And at worst overfire and destroy their modern stoves.
The quote function is available on laptops or phone. There are two ways to use quote.And that that was similar to "All stoves are not designed for overnight fires", where "All stoves" is too inclusive for the statement that followed those two words.
Though it does not give the poster (you in this case), as a Reply does.the new posting, then with the text selected, click on the quote " marks in the toolbar of the post editor. If you don't see the quote ic
But for those of us running cat stoves smouldering is perfectly fine. The cat then burns that smoke. The general premise of his statements is right. But the info overall is just incorrectI consider smoldering to be a lot of smoke, very low flames. I actually hate it to be honest. I try to pick the flames up with fresh kindling. Works for me.
Time to insulate.I helped my neighbor install a Super 27 this year and he still won’t load it up full or burn it overnight. Just throws a couple sticks in at a time and lets it burn out before bed. In the morning he wakes up with his house in the mid 50’s! Brrr!
