why both 7 tooth and 8 tooth sprockets?
jpl1nh Posted By jpl1nh, Oct 27, 2008 at 1:38 AM
Thread Status:
  1. jpl1nh
    jpl1nh
    Minister of Fire 2.
    NULL
    Jan 25, 2007
    1,578
    1
    Loc:
    Newfields NH
    Why does my Stihl 029 Super list both a 7 tooth and 8 tooth sprocket for .325 pitch? Do they both fit the same chains? What's the advantage of each?
  2. aandabooks
    aandabooks
    New Member 2.
    NULL
    May 29, 2008
    141
    0
    Loc:
    Central Illinois
    Chain drive link count yes. 7 tooth more torque-standard setup. 8 tooth-more chain speed but less torque and therefore more prone to bogging in hardwoods if you lean on it a little. If you've go a rim sprocket setup on the saw it would be cheap to try out both and decide for yourself.
  3. Gooserider
    Gooserider
    Mod Emeritus 2.
    NULL
    Nov 20, 2006
    6,737
    10
    Loc:
    Northeastern MA (near Lowell)
    It is sort of like the rear-end ratio in a car - the number of teeth on the sprocket will influence the speed of the chain at a given engine speed, as it will change the number of drive links going past a given point per engine revolution... However unlike the acceleration vs. top speed equation you get with a car, in a chainsaw it's mostly a question of balancing the load on the chain with the engine output at full throttle.
    Ideally you'd like to keep the full throttle engine speed within a fairly narrow range, where it produces the peak torque... You would use the smaller sprocket with a heavier load as that takes less power to turn the sprocket - examples might be a longer bar, or a more aggressive chain. The chain will move slower, but with more power
    OTOH, if you are lightly loading the saw, either with a shorter bar, or a less aggressive chain, then the larger sprocket would give a higher chain speed, but be more prone to bogging if you lean on the saw to hard.
    Gooserider
  4. jpl1nh
    jpl1nh
    Minister of Fire 2.
    NULL
    Jan 25, 2007
    1,578
    1
    Loc:
    Newfields NH
    Thanks, makes sense. I've been running an 8 tooth and it does tend to bog in hardwoods a bit. I'll try the 7 tooth and see how that does.
Thread Status:
