Why did temp go up when I shut damper?
rudysmallfry
617
Milford, CT
So I finally have that nice double wall pipe I'd been dreaming of the past few seasons. I have a damper but not in the recommended spot. The way the pipe is designed, the damper is the first part coming out of the stove instead of 18" above. Anyway, I had a good fire going the other night and had a little too much wood in there. The temp started to rise rapidly even after I had closed off the air as much as the stove allowed. I turned the damper down to 1/2 open only to watch the temp climb instead of fall. Is that a natural short term response to blocking the gases from going up the flue, or am I not getting what a damper is supposed to accomplish? The probe thermometer is 18" above the stove. It was reading 600 at the time I was getting nervous. I had 200 more to go before hitting the red zone, but I know how quickly that can happen if you let the fire run too much before knocking it down.
Mine typically gets up to 800 degrees on the flue probe. On my flue thermometer 600 is dead centre of optimum range. So I don't worry at that point...I have struggled to stay below 900, with the damper closed I've been able to keep it under that 800 mark.
Ian
