Wood furnace vs. pellet furnace
You say that like its a bad thing...>>
If you have never had a stove with a window then you wont miss it...but if you have, then you will...I do.
I was mostly being a smart azz. ;lol
We have a conventional fireplace. I do miss the snap, crackle, pop and smell of an open fire. Maybe we need to find a way to be able to leave the door open too so I can also get back to enjoying those aspects of burning wood too. :p ;lol
Reactions: brenndatomu
OP's house being 2000 ft of new build it may not have a high heat load either...but, he is also in what is typically a little colder area though too. I would still want to discuss with Lamppa the possibility that a VF200 would be a better fit than the larger VF100...
Add to the fact of trying to force hot air down.....my other concern is it seems his supply ducts run in a crawl space under the house.....? if so, how well heated is this space?? I see some issues if he's trying to run his supply ducts in un-heated (or even partially heated) space before the supply air gets dumped into the house. Maybe this was covered already and I didn't see it....? EPA furnaces don't have the raw BTU output needed to overcome those kind of duct losses.
Maybe suggest to Lamppa that they come out with a high temp wifi camera to install on the inside of the door. The camera would live stream to your phone, tablet,etc complete with sound effects! :cool:
Could even have simulated video, based on firebox temp, stage of the burn, and damper setting, etc... ;) ;lol
I'll just put a TV on my plenum downstairs and loop this video. Problem solved. ;lol
Heatmax 2 are at the lowest price I have seen. $1799 US.
Good questions.
OP?
Looks like MFP is down to (2) Heatpros...
I am running into crawl space but the crawl is insulated. 2” foam board on all concrete walls it’s stays above 50* even when it’s below 0 outside I hope that’s enough
Are the ducts running through this cooler space insulated well? If not this may be a problem. IMHO.
It is very typical in my area to have supply ducts in the crawl space. They’re insulated and usually flex duct. Isn’t flex a problem?
But yeah, most of the time you just load the firebox and walk away....with a proper heat load it could/would be that way for sure...but OP may be a bit like me in that my house doesn't require mega BTU's to maintain temp, plus we have had a couple pretty mild winters since my VF100 install...anyways, since I am often running at about the bare minimum I am often scrapeing around for the last few coals to get things fired off again, so sometimes I will sit there for a few minutes to make sure the fire takes off.
OP's house being 2000 ft of new build it may not have a high heat load either...but, he is also in what is typically a little colder area though too. I would still want to discuss with Lamppa the possibility that a VF200 would be a better fit than the larger VF100...I assume the VF200 will be re-released here shortly, @lampmfg ?
When we went back to test the VF200, they had installed new filters that hadn't been present during our previous R&D testing. We have been going back and forth with them for a while about how to remedy the issue. Before proceeding, we want to see how things play out with the EPA's handling of the Firechief Phase 2 model. We are shooting for the fall, but it's not set in stone.
