Wood pellet stove exhaust plenum goo! What is the cause?
Don2222
9,117
Salem NH
Hello
Put the manometer on the hose barb behind the fire box and got -0.27 wg after cleaning out the top of the upside down horseshoe ash chamber. So I cracked the cover to the exhaust plenum and to my dismay saw some very shinny creasote. It looks real sticky because it is real sticky! See pics.
I removed the combustion blower and got out the Acetone and paper towels! Then some dry moly when clean!
I do not see this very often. I know bad pellets can cause this. Could there be any other cause?
You know, you can use hot water instead of acetone. At least for the initial cleaning.
Is this the same piece of crap baby-m that had the hopper fire?
Let's see....
  1. had a hopper fire
  2. has creosote in the exhaust
  3. needs a new burn pot
  4. needed a new auger stop plate
  5. Needs a new heat exchange raker
less than 4 years old
Sounds like a stove worth paying 2k for.
Reactions: will711 and libirm
Let's see....
The new stoves come with all these improvements and they did not raise the price! So what A line stoves will you have in your new store?
I bet they were burning those new oil-infused Inferno pellets:cool:
Could be. LOL
The interesting part is the fact that it was most liquid at the bottom of the round exhaust plenum. The ash chambers and other parts were dirty with ash but not shinny and goopy like where it is in the pics.
Hell O
If it is creosote, here is a study done by Uranus University on how it is caused in a wood burning appliance. I feel the same issues are also applicable to pellet stoves.:cool:
Creosote may build up to a considerable thickness on the interior surface of the chimney and the draft opening may subsequently be reduced. A serious fire may be ignited if creosote is allowed to build up. Most problems with creosote are due to poor chimneys with a low draft and cold walls.
You can reduce the creosote problem several ways. Smoke density can be lowered somewhat in an airtight stove by using small amounts of wood and stoking more often or by using larger pieces of wood. Creosote formation can be limited by leaving the air inlet or stove door slightly open after adding wood to promote more rapid burning until the wood is mostly reduced to charcoal. Then close the inlet as desired.
Allowing this extra air causes more complete combustion lowers the potential creosote-forming gases and generates additional heat to the surrounding area. Vapor in the flue gases may be controlled by using the driest wood possible and using only small pieces of wood during mild weather when combustion is relatively slow. The stack temperature can be raised by insulating the stove pipe connection so that it cools as little as possible before reaching the chimney. Using an insulated pipe also aids in increasing the stack temperature.
Draft can be increased by having as few bends as possible between the appliance and the chimney, having the proper height and diameter, keeping the chimney in good repair and by having a separate flue for each appliance. Also use proper sized stove pipe. In a large chimney, draft can be increased by decreasing the flue size. This can be done by installing a new smaller flue or a stainless steel stove pipe liner.
In many airtight stoves, a sealed overnight fire will deposit creosote even with dry hardwood. To dry the creosote always open the draft caps and let the fire burn hot for at least 5 minutes every morning and again before bedtime.
Hell O
Trading information here to help each other is what this forum is all about. Thanks Defiant.
It makes sense that insulating the chimney liner to maintain stack temps helps to eliminate creasote buildup
Also what is key here pertaining to pellet stoves is that good air flow is also needed to properly run stoves and prevent buildup.
Therefore the fact that creasote has built up in front of the original 85 CFM exhaust blower may be telling us that the new upgraded 105 CFM exhaust blower is truly needed here. After installing the upgraded blower, the manometer read -0.84 that is approx .55 difference! Interesting I only read 0.62 at first but then I realized the firebox door was not shut tight. LOL Also there was no change in the reading when the new ash pan door gasket was installed. I still have the original door gasket but I plan to change that and take another reading.
I seems now this 7 year old stove will work better than it ever did before!
See pics, click to enlarge.
Baby Countryside is all that needs said.
Almost all are a danger to run unless updated or modified.
thanks Dexter, I have been working very hard on updating these stoves
As the gases cool(further in the system).... The goop starts where it cools enough to Sote up.
SOTE in box? Nope. Sote in plenum? Yep. Cooled gases. Add in that Babys burn Chitty? And it all makes sense
Good point Dexter.
Why do you think the exhaust gasses maybe cooling in the exhaust plenum so quickly?
Um? Why did it have a hopper fire?
Inefficient combustion and a chitty burn.
Incomplete combustion causes a bad burn? Which causes the nasty stuff.
The background is:
It had the corn pot in the stove and the control board jumper on pins 2-3 which is better for corn
Wood pellets were used and there were some burned pellets in the hopper. Also the venting went straight thru the wall and then a 3 foot vertical rise on the outside of the house. The Magnum Baby CountrySide stove manual specifically states NOT to install it with the vertical rise outside!
The venting going straight outside could definitely contribute to cooling the gases in the exhaust plenum! Thanks for helping think of that Dexter. :)
You guys are good!
There are alot of factors here!
See diagram in manual below
"This type of installation is NOT recommended cold climates unless closed in and insulated properly!"
hm, as you do more of these, Don, you'll actually "get to know" each stove and installation, just like their owners, and, you'll see that certain units behave differently for a myriad of reasons....a properly burning stove for several years, THEN some creosote? Somethings changed.......I wonder what? (usually a cleaning issue, but can be indicative of a failing part, or that &*^% squirrel again!).....
Also water versus acetone......both work on creosote- water is cheap, but can cause rust...acetone is more spendy, smells, and cause cancer (but arguably works faster)....we use soapy water
Thanks for the tips
Since I must use Acetone to cleanup good before painting, I have plenty around. To me the Acetone is much faster and for $7 a can that lasts a long time, my time is worth much more! I also have one of those painters breathing masks. The ash chambers in this baby were pretty clogged when I brushed and blew them out with compressed air. That buildup could have been the change that trigger everything. The new upgraded exhaust blower will help. Proper installation and proper maintenance is the only way to keep any stove running well.
I will be replacing the door gasket today which is frayed and worn today. Then the fun part of firing up and testing. :) I will let you know how it performs now!
The control panel membrane had holes from wear. You could see the micro switch buttons. Luckily, I had a good one from a junk panel I swapped in. Magnum does sell just the membrane cheap unlike other companies which is good for my customers that do have these stoves for a long time. Even though the auger motor was working I put a new 2 RPM Gleason-Avery in there for good measure. :) It did run for 7 years, I have seen very good stoves quit after 3 years from no maintenance! This the fun of fixing pellet stoves I guess. :)
