Woodstock Progress Hybrid Video
Todd Posted By Todd, Aug 9, 2011 at 4:45 PM
Thread Status:
  1. Waulie
    Waulie
    Minister of Fire 2.
    NULL
    Aug 31, 2011
    1,011
    272
    Loc:
    Nothern Lower Michigan
    I with you on that! Maybe you could send a check? I use my card for convenience when needed and just pay it each month. I won't allow those companies to get rich off me.
  2. BrowningBAR
    BrowningBAR
    Minister of Fire 2.
    NULL
    Jul 22, 2008
    7,607
    1,107
    Loc:
    Doylestown, PA
    As long as they promise to not cash the check until next August, I'll write them as many checks as they want! :lol:
  3. Todd
    Todd
    Minister of Fire 2.
    NULL
    Nov 19, 2005
    9,229
    349
    Loc:
    Lake Wissota
    Maybe they have a lay away program?
  4. BrowningBAR
    BrowningBAR
    Minister of Fire 2.
    NULL
    Jul 22, 2008
    7,607
    1,107
    Loc:
    Doylestown, PA
    I'll see if there is a way for me to lock in the price and stretch it out longer than the March 2012 that they have listed on their form.
  5. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    Let it be known that you can charge things on your credit card and still not have to pay interest. I have a card that we've had for probably 25 years and have never paid interest and we use that card a lot. No, I don't like debt either and it really gets my goat when I see businesses advertising to sell something for so much down and so much per month. Just tell me what the danged thing costs and leave the figuring to me.
  6. fire_man
    fire_man
    Minister of Fire 2.
    NULL
    Feb 6, 2009
    1,944
    395
    Loc:
    North Eastern MA
    I have a dumbish question about the new stove. Assuming you order it with no legs ("Plinth base"), how the heck do you move this beast into it's final resting spot? It rests directly on its frame, no air space under it. You cannot get a dolly or your fingers under it to guide it. Just asking?!?! :eek:hh:
  7. BrowningBAR
    BrowningBAR
    Minister of Fire 2.
    NULL
    Jul 22, 2008
    7,607
    1,107
    Loc:
    Doylestown, PA
    Tilt, corner, corner, tilt, corner, corner.
  8. begreen
    begreen
    Mooderator 2.
    NULL
    Staff Member
    Nov 18, 2005
    64,806
    8,589
    Loc:
    South Puget Sound, WA
    Just put something under it to move it. A sheet of metal for it to slide on should make it go in pretty easy.
  9. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    Tony, it sounds like a piano dolly would work fine.
  10. teutonicking
    teutonicking
    Feeling the Heat 2.
    NULL
    Aug 18, 2011
    387
    268
    Loc:
    Maryland
    From what you know about this new stove, is it expected to produce more heat than the Jotul F 600, less, or about the same? It sounds like the firebox is slightly smaller on the Woodstock (2.7 cubic feet vs. 3.2 for the Jotul) but the BTUs sound about the same (around 80,000 max). Perhaps the Woodstock acheives this by better efficiency? I have a pretty large space to heat (2800-3600 square feet, depending on which rooms I close off); just wondering which would be better. I am considering modifying my hearth for the Jotul, so this would be the perfect opportunity for me to get this stove since I can change the plans on the hearth to accomodate this one to fit perfectly. This one also costs a bit less and includes soapstone, which is nice. The Mansfield would cost a lot more. I understand this stove won't be available until Halloween at the earliest. Another question--would any dealers install this for a fee, even though Woodstock sells stoves directly? I would not do it myself. I live in Maryland near Washington, D.C. Thoughts appreciated--thanks.
  11. ddddddden
    ddddddden
    Minister of Fire 2.
    NULL
    Oct 20, 2009
    1,348
    168
    Loc:
    Central Va
    Pretty much no stove has as much usable space in the firebox as the mfr spec for firebox volume states. Apparently the mfrs like to include inaccessible air space. . .so you can count on the F600 holding 3.2 cu ft of air. I don't know if anyone here has posted measurements for an F600 firebox. . .you could post a thread asking for F600 measurements. Also unknown is whether the "2.7" from Woodstock is the official spec or a ballpark number for real world usable space. Which stove to get? Well, I'd get the Woodstock, but I'm biased. :) The F600 is supposed to be a pretty good heater. Jotul has been having some problems with their enamel finish recently, so I would not get an enameled F600 at this time. Regarding installation, most shops probably would not want to do it, but might if you bought the chimney from them. Your best bet would be an independant chimney sweep, which is how one shop in my town handles installs.
  12. ddddddden
    ddddddden
    Minister of Fire 2.
    NULL
    Oct 20, 2009
    1,348
    168
    Loc:
    Central Va
    Regarding efficiency, yes, Woodstock seems to be trying to set a record, but we don't have any numbers yet. The stove is going through final testing now. . .should hear something in a few weeks. Maybe it will be 10% more efficient than the Jotul, but maybe it holds 10% less wood, so peak output would then be the same, but the Woodstock would get it done with less fuel. When you don't need maximum heat, the Woodstock should do a low burn much longer than the Jotul. (We're hearing 12-16 hours. The catalyst allows you to turn the air way down and still get a clean burn.) While we're waiting for test results, maybe you can get Woodstock to tell you the firebox dimensions. Calculating the volume will be a lil' tricky though, as the ceiling of the firebox is sloped.
  13. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,325
    2,080
    Loc:
    Cascade Foothills, WA
    Note in their blog that the lame Progress name is temporary. They are open to suggestions still. The blog shows a nice low/medium burn but nothing really low. Hopefully this stove isn't burdened with a hot low setting like the typical non-cat.
  14. Tim IA
    Tim IA
    New Member 2.
    NULL
    Nov 9, 2006
    59
    0
    Loc:
    Central Iowa
    I'm assuming it can be turned down fairly low if they are expecting 12 - 16 hr burns with this. I'm sure they have it figured out.
  15. teutonicking
    teutonicking
    Feeling the Heat 2.
    NULL
    Aug 18, 2011
    387
    268
    Loc:
    Maryland
    I think I am leaning towards getting this new Woodstock stove. The timing is perfect for me--I can have the modificed hearth built and ready by the end of October just in time for the arrival of the new stove in early November.
  16. ddddddden
    ddddddden
    Minister of Fire 2.
    NULL
    Oct 20, 2009
    1,348
    168
    Loc:
    Central Va
    Excellent choice, Sir! You are clearly a man of impeccable taste and timing. Some folks have been salivating over this stove for a few years now. If you want to be ready to roll when the stoves arrives, you should start planning the chimney as well as the hearth mods. What are you doing for wood?
  17. teutonicking
    teutonicking
    Feeling the Heat 2.
    NULL
    Aug 18, 2011
    387
    268
    Loc:
    Maryland
    Thanks. I have been planning this for awhile so I have about five cords of wood cut, split, stacked and covered in my yard. I was worried I might not have enough, but since I won't start burning until mid-November I think I will be okay. Plus this new stove seems pretty efficient so i may only burn 3 or 4 cords this year.
    By the way, I like your picture. Now that's what I call a "Cat" stove.
  18. ddddddden
    ddddddden
    Minister of Fire 2.
    NULL
    Oct 20, 2009
    1,348
    168
    Loc:
    Central Va
    Thanks. The cats were all over the Fireview even before it came off of the truck. I'll have to UL some more pics one of these days. . .
  19. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    You can be served well with the installation by a sweep but you can also be served well by a carpenter. So long as they know clearances and height of stove, etc. they should be able to do it with no problem. No matter what, I would have them go a bit beyond code. Code says 2", why not go 3" or 4"? Does no harm and gives you a bit more peace of mind.
    You do indeed have a large space to be heated. I hope you have read about the small fan trick of blowing cool air into the stove room. It works much better than blowing warm air.
  20. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    Great that you have the wood already. Just a little kicker here. When we bought the Fireview we reduced our wood needs by half. Most don't get quite that much but we surely have and we stay a whole lot warmer too. I would expect the same for the big stove. And don't forget, Woodstock has the best guarantee!
  21. Battenkiller
    Battenkiller
    Minister of Fire 2.
    NULL
    Nov 26, 2009
    3,740
    19
    Loc:
    Just Outside the Blue Line
    Very impressive. I want one.
    Now the question is, "What size house should I get to wrap around it?" :lol:
  22. Todd
    Todd
    Minister of Fire 2.
    NULL
    Nov 19, 2005
    9,229
    349
    Loc:
    Lake Wissota
    Looks like the new stove isn't the only stove on sale. You can get a new Fireview for $1895! Get em while their hot!
    http://www.woodstove.com/sale
  23. Tim IA
    Tim IA
    New Member 2.
    NULL
    Nov 9, 2006
    59
    0
    Loc:
    Central Iowa
    That is an incredible price for the fireviews!!
  24. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    I agree. Those are some fantastic prices.
  25. metalsped
    metalsped
    Feeling the Heat 2.
    NULL
    Jul 24, 2011
    297
    67
    Loc:
    In the slight space between dark and light
    I am not big on the styling of the Woodstock stoves.... but this new one is purty!
Thread Status:
