‘76 Defiant pouring smoke out of the back when side door is open
Greenmason
10
Massachusetts
Old stove that came with the house we bought this summer. Chimney has been cleaned. Stove has run fine since October. Backplate was bowed with a crack in it which still remains obviously. As of today when I go to load more wood it billows smoke out this back top corner as far as I can tell. Crack in the stove? What would you suggest. Had been firing it hot with this cold routinely up past 600 degress plus before I close damper
[Hearth.com] ‘76 Defiant pouring smoke out of the back when side door is open [Hearth.com] ‘76 Defiant pouring smoke out of the back when side door is open
It probably needs to be resealed. With a bow in the fireback, the secondary air system is probably no longer working so its not a very efficient stove. If its two piece fireback, it may be worth replacing the two pieces (sometimes its just the top one) and restoring the secondary air channel. If its one piece fireback the conversion parts cost more than its worth and unless the stove is rarely used like in hunting camp, its time to look for a replacement.
Reactions: Greenmason
Thanks for this. Yea its a one piece, have looked into it. Plan this summer is to build a masonry heater upstairs and move this stove downstairs and tie it into where old wood furnace was and use it sparingly
I happened upon a D1A1 that needed a lot, had a D1, i had to buy new backs and a baffle, between the 2 I made one, it wasn’t super cheap, probably 500 in parts, but honestly it is a great stove, and I wanted it for my basement, I am very happy, you cannot buy a new stove for what the parts cost.
Reactions: rwh63
