Greetings from the great Northwet!
I have a new-to-me VC 0029 manufactured in 1989. Just got the permit and got the stove running after 4 years of installation. This is my first "modern" woodstove and been a learning curve (cat? you want me to put a cat in the stove? It now has a new cat... a pretty expensive one too), and using the stove is also different than the air tight stoves of my youth, so I am not sure is the issue is the stove or the operator. So bear with me.
When the stove is cold the air vent clearly controls the fire. Even for the first ten hours of use. But every evening after hours of 500-600 degree griddle temps the fire quits responding to reduced air vents, and the only way to control it is let it burn down to 450 add one or two logs and even with the vent closed they will flame up fast back to 600 or so and then burn down. I suspect an air leak but I replaced all the gaskets except the glass gaskets because the chimney sweep who inspected the wood stove said they were fine. When I checked out the glass this morning there is a little side to side play in one glass plate (maybe 1/8") and I see what I am assuming is a thermal expansion gap between the glass and the metal on the stove. Is this normal?
Also how do you tell if the thermostat needs replacing? The handle moves up and down and for about ten hours a day the fire responds to the controls, but I am wondering if it isn't expanding all the way anymore? Kind of a drag to put a wear item in a tough to reach location like that.
Other than that it has been great. I have been letting it die out at night because of the issue with controlling the temp but it runs great all day and haven't turned the heat on in two weeks. Can't wait to get my next electric bill!
Thanks for your help and here is a picture. Yes it still needs trim on the stone and a hearth... my wife mentions this about 3 times a day.
