I installed the Honeywell thermostat from ESW last winter and now I'm having an issue with it. The thermostat for the stove (Honeywell) is installed about 2 feet from the thermostat that control the AC and Heat Pump (EcoBee) and both are about 20' from the stove. My issue is that the Honeywell thermostat will not keep a consistent temperature in the room. For example, if I set the Honeywell to 76 the EcoBee will read 79 when the Honeywell stops calling for heat. If I set the Honeywell to 75 the EcoBee will read 71 when the Honeywell stops calling for heat. Has anyone else had a similar issue? Or can you recommend a better thermostat to use?
