2 Quick Questions On Double wall Stove Pipe
Dix
6,716
Long Island, NY
The Dixettes getting chilly :)
She went to Home Depot, and picked up the double wall chimney, but couldn't find a double wall elbow.
Do they make a double wall elbow ( I've seen one, I think), and if they do, are brands interchangeable, say Duravent & Selkirk?
Or, can we mix a single wall elbow, as long as clearance to combustibles are met?
We're talking on the Timber Ridge.
Chimney or connector?
Yes they make them & no the different brands are not interchangeable OR compatible
NO
NO
**ok so why can't you mixit if they fit and appear to connect? what if i use a single wallpipe all the way through? i think my cleareance is good all the way around? what really is the difference? if its interior and clearsall the distances its supposed to. I'm only asking so i can completely understand. I really just want to get it done!**
<>ok so why can't you mixit if they fit and appear to connect?<>
Because they are not tested to be used together & because you are putting fire in your house. If you mix & match untested combinations, you just might burn your house down
<>what if i use a single wallpipe all the way through?<>
As long as you meet the specified clearances, & EVERYTHING is installed securely & correctly, you should be good to go
<>i think my cleareance is good all the way around?<>
Think? Freddy Prinze didn't think the gun was loaded
<>what really is the difference?<>
The difference could be life & death
<>if its interior and clearsall the distances its supposed to. I'm only asking so i can completely understand. I really just want to get it done!<>
If you are installing connector pipe it HAS to be inside. If it's single-wall & unshielded, it HAS to be 18" away from combustibles. Otherwise it's NOT SAFE. I've said it before, "Fire will do two things: 1) It will HEAT your house. 2) It will EAT your house." It doesn't care about you. It doesn't even know you're there. It just wants to burn. If you do not install your wood burning stove & ALL of the necessary components correctly, the consequences can & will be deadly. I understand you want to get it done. GET IT DONE RIGHT.
[/quote]
