2 story house
lukex3
4
western, VA
Also, I was told that the best way to install a pellet stove in a 2 story house (downstairs) is through an outside wall, because the flue is too high. I have this one hooked to an existing flue I had for a wood stove, then later to an oil stove. Do you think this has anything to do with the E1 Vacuum error code I am getting??
You need to describe exactly what type of exhaust set-up you actually have. pics would be nice too.
BTW, try to open just 1 thread for the issue you're having.
i have a 3 inch pipe going into a 6 inch flue going 2 stories 15 feet high. I installed the OAK, going outside. Sorry, no pics yet.
Should have nothing to do with the error code. I have my stove going into 8" wood stove pipe that is about the same height.
When you start it, what settings are you running on?
I know you just got it, but have you messed with the bottom 3 buttons any?? If you haven't, then dont!!!
Welcome to the Forum. And I will 2nd the single thread for your problems.. Just ask multiple questions within one thread. Lots of fine folks around here to help.....
lukex3 said:
it usually dont make it that long before it cuts off my bottom 3 is 6 5 an 1 do i need to change it
If your combustion blower isn't running you'll always get the E-1.
