I bought a used Harman accentra 2002 free standing model. Serial code number 1278. Have replaced the door, window and hopper gaskets. The feed motor and exhaust motors were failing so it was replaced with OEM Harman parts. Circuit board was also replaced. Have now been having consistent 2 blink code at the same time...stove will go through ignition sequence with what appears to me to be a good flame characteristics. The stove ignitor light will discontinue and the feed motor/light will cycle on and off. The distribution light/motor will come on and around this time, the 2 blink light will come on. I have cleaned the stove from head to toe. Cleaned the fines compartment. Then gasket is thin but intact and have made sure the wing nuts are tightened. Have replaced the vacuum sensor. I have put 3m fire sealant around the base of the stove and cabinet seal inside burn area. The tubing coming off the sensor allow air to go through it. The esp sensor is new. it is a black ESP. After it cools down for about 20 minutes the status light will turn solid and the feed motor/light will cycle on and off and try to continue. Have run out of ideas. Help?
