Hi:
Looking for some help with an ep refurbished stove. It seemed to run fine initially almost no Ash, etc. Then the burn pot started filling quickly with a hard mass and heavy Ash. Following other threads I cleaned out behind the clean out areas and ceramic board. I made certain the control board was in mode 2 and used settings 1 4 1, I had to boost the middle setting to 6 in order keep the fire box clear of Ash. It still doesn't seem right the Ash is very thick and builds up around the firebox and on the window very quickly.
What else should I be looking at?
Using the oak that came with it. 3" vent 45 degrees to outside 90 degree to about 6 feet of vertical. I am chiefly burning Somersets along with Greene Supreme and a variety of cheap pellets.
Thanks for help
Julian
Thanks for help
Julian
![[Hearth.com] 25-ep stove Ash build-up [Hearth.com] 25-ep stove Ash build-up](https://www.hearth.com/talk/data/attachments/119/119177-844445449c098cf2711733ffd4c0d453.jpg?hash=xtcx-k1x9X)
