I thought I knew the ins and outs of my stove pretty well but I am stumped.
Stove will start, feed pellets, top auger will stop, fire will go out, top auger will feed pellets onto hot coals, fire will start, then cycle repeats. Doesnt matter what settings are. Tried 6,4,1. 4,6,1 on heat ranges 1 and 2. Tried all other heat ranges. no joy. Stove will just not heat up. It acts like its overheating and cycling on the temp sensor. Heres what I have done so far. losing my marbles. If it wasnt so heavy I would have tossed it over the deck rail. Stove bought new in 2014. Burn plate is a bit warped. some cracks by the back exhaust ducting. Only thing left is the control board. I did that a few years back when it wouldnt power the combustion fan.
Cleaned it like never before
Changed top auger
Changed both vac sensors
Replaced all hoses
Replaced temp sensor
Bypassed vac sensors for troubleshooting
Cleaned stove again
Made sure jumper is in T stat plug
bypassed hopper switch for troubleshooting
Cleaned stove again
Checked hole in heat box for vac sensor.
Thanks in advance for any help,
Scott
Changed top auger
Replaced all hoses
Cleaned stove again
Cleaned stove again
Scott
