Warm_in_NH
Don't let your house freeze, like the others have said, there's a lot of places that water is still going to hide once you think it's empty. I also doubt it's even set-up to be properly drained / winterized with blow-out fittings to hook the compressed air up to and really clear the lines.
Also agree with the fact that if you ran your burner out of oil and let an empty tank sit for some time, it'll probably need a "service" at the very least the furnace will need to be primed prior to firing (google your make and model for instructions on that)
Personally I would use it as my Ace up my sleeve as a perfect reason to avoid the in-laws over the holidays. If that's not an option, you may consider buying a freeze thermostat switch :
http://www.amazon.com/Farm-Innovato...=1387316633&sr=8-1&keywords=freeze+thermostat
and plugging your heater into that in the basement near the pipes, oh, and make sure your homeowners insurance is paid up.
  My neighbors are probably going to wonder if I'm burning sandlewood...  I'll find two or three of those 3-wick variety and hopefully it won't be a toot in a hurricane, so to speak.
