A place near me has wood that came from the infamous Sandy superstorm of 2012. It is just being split now. Would it be ok to burn in a woodstove this winter ?
Really hard to say based on the info provided. Like turn n burn says it will depend on the species but also on how it was stored in log form. Were they all together packed tight or were they up off the ground alone and in the sun? You say its just being split now, does that mean it was in round form for awhile or was it in log form until recently? Best thing to do would be to use your moisture meter and check the mc on a fresh cut split. I would think that its unlikely it is near the desired 20% or below. Based on my area even a log of lodgepole pine laying on the ground split now will be 25-30% moisture content if not higher even if it fell over two years ago. I would be hard pressed to get it ready for this burning season. Separate your species and view a btu chart like the one chimney sweep has on his site. The rule of thumb is that green trees will not dry out enough for our purposes without being bucked, split and then stacked for a period of time. The exception is trees that are standing dead for a long period of time. The limbs will be ready first and the trunk last especially as you get closer to the ground. If it was me and I was in your situation I would purchase the wood and process it and use it for future use. If I could pick the species I would avoid oak and denser hardwoods and go for pines and soft maple if you hope to burn it this season. Welcome to Hearth!A place near me has wood that came from the infamous Sandy superstorm of 2012. It is just being split now. Would it be ok to burn in a woodstove this winter ?
The guy said if he split the wood when he got it in 2012 it would be rotten by now. He seperates it into split dates
That's totally BS. When people spout off BS like that it makes me question everything else they say.The guy said if he split the wood when he got it in 2012 it would be rotten by now.
