Hi guys! I've been away for a bit occupied with other things, but find myself once again in need of the great collective wisdom of the boiler room!
My garage attached to the house is really a small car port (11x21 floor). I am converting it into a home office and plan to take up the 60 year old frost heaved floor and put in a heated slab. I was looking at (broken link removed to http://www.radiantcompany.com/details/grade.shtml) page as a reference for how to do it. I would like to know from peoples experience if this is the right approach. I live in northern Vermont so I assume I need 2" of the Extruded Polystyrene foam insulation under it and on the sides. The floor will be 231 sq. ft. and require 2.8 cubic yards for a 4" slab (I think). I have 70 feet of 1/2" pex tubing left over from my staple up radiant floor project. The directions say I will need to put this in with 8" spacing with 1/2" pex, so I will likely need another role of tubing. I estimate I will need to make 14 to 16 runs of 21 feet to get the 8" spacing. That means 294-336 feet of tubing plus the amount needed to make connections in the basement. Does this all sound right?
Lastly, if any northern Vermonters have left over materials (insulation, pex, etc.) from their own slab projects, I will gladly take it off your hands. I also need fiberglass batting for the walls if you have any of that laying around taking up space. PM me and I will see if picking up the materials is feasable and cost effective. Thanks for the help
- WNO
- WNO
