Hooked up the thermostat to my 55-TRP-10 today with less than stellar results. Actually, there was no change in operation with or without the thermostat.
The thermostat test shows the unit can see the thermostat calling for heat. The jumper on the controller was removed to install the thermostat wires.
Changing the setting on the thermostat does not cause any changes in the operation of the stove, I even waited to see if it takes a little while.
Stove was set for 9-9 and I was expecting it to drop the burn rate and room blower down with no call for heat.
Any suggestions?
Any suggestions?
