Hello folks. I recently acquire an All Nighter Mid Moe and would like to install it in a shed that has an existing exterior masonry chimney with 7" square flue. The chimney is in good shape so I'm wanting to try burning it with the stove pipe just routed to the existing chimney, and see how it drafts. Any thoughts on how it may perform?
My next question is if I were to decide I wanted/needed a liner, is a 6" liner going to fit into a 7" flue? My initial thoughts are that it will not. I believe I will need a Tee where the stove pipe passes through the side of the chimney, and the ones I've seen dimensions for exceed 7" so would not fit down the chimney.
Is going with a 5" liner an option for such a stove? Do you expect the stove to function fine just using the current 7" square tile flue?
