Why should the reducer technically be installed at the flue collar?
As begreen mentioned the cleaner looking install is going to have the reducer at the thimble.
Yes and that is a bad thing you want to loose as little heat from that pipe as possible especially when you are going to be going into an oversized flue you will need all the heat you can getAesthetically I agree, but radiant heat is directly related to surface area and a 8" pipe have 33% more surface area then a 6" pipe, thus more radiant heat for a 8" pipe than for a 6" pipe for a given flue gas temperature.
No i saw it but no matter what the stove or wood is after it leaves the stove you want to loose as little heat as possibleYou obviously missed my prior qualifier.
My concern also. It's unknown what the 8" thimble is connected to.Many many people vent six inch outlet stoves with six inch pipe dumping into oversized masonry.
Technically unless the stove is a smoke dragon being fed wet wood, the reducer should be installed immediately after the stove outlet. This means a longer length of larger diameter pipe to radiate heat out into the room. I also would expect slightly higher heat transfer due to lower flue gas velocity. The trade off is sometimes with wet wood and a marginal stack you want to get the gases as soon as possible put of the stove and into the chimney, best case is it keep the creosote buildup inside the chimney instead of in the stovepipe. It also may keep creosote from dripping out of the pipe at seams.
There are so many innaccuracies in that post i dont know where to start. But magic heats are without a doubt one of the worst inventions associated with eood stoves that i have seen. Those and the fan draft inducers you cut into the pipe.I dont agree with your contention. If I have seasoned wood and clean burn in an older stove, I have no problem with cooling the gases by radiating more heat into the room via the larger diameter flue piping. Heck I could even use a magic flue in that situation and actually did with my Fisher clone for a few years. My old Fisher clone and even my Defiant put out some serious heat up the stack, I would much rather have it in the room and burn smaller intermittent loads than heat the outdoors and that supports going with the 8" as soon as possible. After a day of burning, the entire chimney would be warm all the way to the attic. I went for years between chimney cleanings and usually do it out of guilt rather than need. My boiler definitely puts out far less heat into the chimney but since I burn it flat out with dry wood to charge up my storage its not going to plug up my chimney as the only way one gets creosote is incomplete combustion. Realistically with a clean burn you can run the stack temp way down to the dewpoint and all you are going to get it water vapor condensing as all the combustibles are long gone.
No skin off my back if folks want to burn their houses down by running a stove for long durations on less than ideal wood by cranking down the damper and starving the air for hours on end One of the tricks to comply with EPA regs was to hide secondary air ports or install stops on the air inlets so that folks couldnt fully crank down the air yet I read on occasion how people plug these ports to get longer burns.
Feel free to waste your time listing them, I wont see them as you are now ignored.
Having a bad day, peak? Im sorry to hear it, and, I understand, we all have them.Feel free to waste your time listing them, I wont see them as you are now ignored.
The bad part about the intensifire thing is it may be a very good idea. It tested well. But he was making outlandish claims about apsolutly perfect complete combustion. And would not even give a basic overveiw of how it functioned. What really got me was when he said there was no point in trying to explain it because there is no way we could understand it anyway.Having a bad day, peak? Im sorry to hear it, and, I understand, we all have them.
We are among friends here, and bholler, for all his abruptness, is one of the most valuable members of this community. Obviously smart, experienced, and eager to help. I'd need periodic refreshers from charm school as well if I did what he does for a living.
You'll be missing out on some excellent advice if you keep him blocked, as well as some fine entertainment. Remember his exchanges with that guy from New Zealand with his miracle stove a couple years back?
Well, we still have bholler doling out his excellent and entertaining advice. That guy from NZ and his miracle stove are nowhere to be found.
I also value and enjoy your posts, I count on you for your intellectual and research prowess.
Often, two intelligent people disagree. Our best growth opportunities occur at these moments.
I am very optimistic about the future of heating with wood because of the type of people who are interested in it, and the modern rapid advancement of technology. I also believe that folks who are unfailingly stubborn have a greater chance of success.The bad part about the intensifire thing is it may be a very good idea. It tested well. But he was making outlandish claims about apsolutly perfect complete combustion. And would not even give a basic overveiw of how it functioned. What really got me was when he said there was no point in trying to explain it because there is no way we could understand it anyway.
But i wouldnt dismiss it as gone yet. Getting a new product to market csn take a long time
