New member here. I have an American Harvest 6039 stove in my man cave in the barn that has quit working. The auger motor get power (can hear it try to start) but the shaft will not turn the auger. Cleaned all pellets, disconnected the power and used the lamp cord test to try to fire it up. Same thing, can hear it try but the shaft will not turn. OK now for the question: I assume I need to replace the motor but I can't figure out how to get the old one out. I've look online to no avail for a video or instructions. All I find are related to the 6041 and the older unit is not the same. Any direction on this would be most appreciated.
Secondly, when I look for the replacement the new units do not look the same as the one I'm replacing. Mine has a little fan on the end of the motor and the new ones do not. Also the old one has two male vertical electric connectors/spades that the attach to the wiring harness. The new ones have female connectors, except the one USSC sells. Even this one does not have the fan.
Last, can you suggest a good place to get replacement glass and ceramic brick fire box backer?
Thanks so much.
Roko
Thanks so much.
Roko
