New Guy, New House, New Adventures In Heating
DieselWeasel
1
Geauga County, Ohio
Hi everyone,
I am new here... not completely new to wood heating as I had a wood burning stove in a house before. However we just moved into a house that's new to us... built in 98. The house came with a HotBlast 1800 wood burner. We used it a few times with some wood that the prior owner left behind because this house has an electric furnace and WOW do they suck. Coming from a gas home, electric is a joke.
The wood burner heats the house great however, it PLOWS through wood. The prior owner said he tried coal but could never get it to light off and run well. I decided to give it a try anyway. I went and got 500# of Anthracite for like 40$. I tried and failed to light it once. Then went online and found a suggestion for using charcoal. The first time it was some OLD stuff and took a bit to get lit. However, it kept us warm for 3 days. My wife got pretty good at raking it back and adding coal. I don't think between the 2 of us we were shaking it enough though. She ended up going out one day on mu wife when she got home from the store. Just today I totally cleaned out the furnace. The shake grates were out of their holders because of all the crap under them anyway.
I just got her going fully loaded in 10 minutes using charcoal again. Being new to furnaces and coal I don't really know how hot everything is supposed to get. There is a "home saver" thermometer on the stove body. It probably didn't come with the stove. It is on the front of the exposed firebox above the feed door near the flue control. It says best operation with a range of 250* to 475* above that is TOO HOT and below it is CREOSOTE. Not sure if its the same range for my furnace or coal. Last time I could only get the gauge close to 409 once. But always averaged around 300. I was NOT using the power blower except during/after feedings. I also don't really know what settings to use for best output on flue and ash door. There is no feed door vent on this one. Only below the grates on ash door.
Any suggestions would be awesome.
Thanks!
Where hearth.com is all things wood, the folks at http://nepacrossroads.com/ are the go to folks for coal burning. Not much coal burning done by our members that I have seen.
BTW: Welcome to the Forum.
I burnt a little coal in a garage stove I had probably 20 years ago and had an uncle that always burnt coal in a warm morning stove. I think it always worked best getting a good fire going with some wood before adding the coal. Also those temps you mention do not seem very high if you read a lot of the posts on here most folks have their stove cruising at 500 to 600 but not sure where you taking that temp at. I am sure some others will chime in that may have more experience with coal.
