I have built a 5,000 gallon, non pressurized storage tank. This tank went through a few design changes before construction started as well as a few more during the build.
I originally researched building a masonry stove but my house is large and long. I had been using a Defiant wood stove for supplemental heat but the issue I ran into is the south side of the living room had 54' of floor to ceiling glass. Old Anderson ⅜" glass. With the Defiant burning happily away it would be 75° near the stove but down to 40° near the windows. I was first looking at ways to distribute the heat. Then how to store and distribute and could not come up with a suitable way to utilize what I had. It became time for a rethink, and this is the direction I went.
The beginnings.
I decided that I did not want to install the new boiler in the basement, long term forecast is that my bad leg won't get stronger and my back will get worse so needing to go up and down stairs repeatedly 10 years from now was not an attractive idea. I also eliminated the idea of an outside boiler. I do not want to wake up and go out to load a stove on a frigid morning.
So we went with a new addition, great the house is too big as is. But an addition it will be.
The original tank design was to build a block foundation on two walls and utilize existing structure on the inner walls. I was not sure how well I would like this idea since one wall was a non mortared piled stone foundation. I figured I would just taper that wall of the tank so it would not impose a sideload on that wall. As I got to digging and was down in the hole looking at the house I could see that I had left a basement light on. I should not be able to see that between the top of the foundation and the sill of the house. Might be why a marble on the floor picks up speed as it rolls towards that wall.
Redesign time, It was decided to go with a poured concrete structure on all 4 walls. Big cost increase but had to do it.
Well to start with I had gone out and scrounged a few pieces of 3" thick blue foam,
With the change from block wall to poured concrete I decided to go with the Quadlock ICF system,
I sculpted the ground in preparation of forming the footings,
The way I did these footings was to pour directly between the foam so the sides of the footings are insulated,
I was also going to do a monolithic pour,
the footings and walls were poured all at once so there would be no shear line.
These forms go up like Lego blocks, I hadn't played with these in decades,
The Quadlock system allows for different concrete and foam thicknesses,
Ready to pour,
The pour was done on a chilly December day in 2006
Chilly enough that it was snowing while the truck drove away, But the next morning I was back at it adding another 3" of foam to the 4 ¼ that was there.
Continued, Part 2 in an hour or so,
The beginnings.
Ready to pour,
