Ok, say the wall behind my stove is brick, and the stove requires 16 inches from the back of the stove to the wall. Would that be 16 inches to the brick, or 16 inches to the drywall behind the brick?
			ansehnlich1 said:Ok, say the wall behind my stove is brick, and the stove requires 16 inches from the back of the stove to the wall. Would that be 16 inches to the brick, or 16 inches to the drywall behind the brick?
Shane said:The clearance is to a combustible so you measure to the combustible.
Shane said:I guess I'll take my insane professional advice & understanding of code & go elsewhere then.
elkimmeg said:i guess to clarify everything I will try to post a direct cut and paste i so all can interpet instead of guessing
elkimmeg said:a bick does have insulation value of about r.8 and it does dissipate heat and is is non combustiable
I cn not dissagree with castiron safety is is better to error on a larger clearance that to be less
However. if I come accrost a situation, that I may not like or agree with. and it meets the letter of the code I have to pass that issue.
What has held me back fro posting the actual code is it is in chart form and cut and paste looses its format . Plus it means fireing up my windows notebook and getting off this MAC
elkimmeg said:another point missed is the need of space behind the stove to allow circulation of heat to keep it cooler and not to over fire it.
If the wall were completely non combustiable, it would be prudent to have some free flowing air space behind that stove. Having more is an extra safety margine
we agree on that point
thechimneysweep said:This may be a judgement call for your code authority, but here's how the code jurisdictions in our service area would rule:
If the bricks are touching the combustible material, they will transmit heat. Clearances are measured from the brick surface, as if it were combustible.
If there is a ventilated 1" airspace between the bricks and the combustible material, clearances are measured from the combustible material behind the bricks.
 im at home and do not have a copy of nfp211 here , couldnt see dropping 135.00 for an extra keep home copy (i may just do so if i hang out in here much longer so i can refer to it) elk probably has one to look at so i will defer to him on this. i am leaning towards tom oyens post in this thread and am also one to err towards caution. if you have room to allow for those extra 4 inches, use em. another question, does the unit have an available heat shield? this would make the question a moot point. another thing to look at is pipe clearance, depending on how high that brick facing extends, you may have an issue with single wall pipe if you can move the unit to within 12 inches as single wall pipe must have an 18 inch clearance to combustibles regardless of how close the unit can be placed. using shielded pipe , or double wall pipe may be a must if you fall under this measurement (wasnt asked about but i figured i'd toss that out.)elkimmeg said:You are right NFPA 211 is not a national reconised code outside fire depts has no jusisdiction unless given so by the building inspector. The one reconised code nationally is the Internation code c group the only one with national reconition in all 50 states Gass codes have no right being applied to solid fuel or oil burning appliances they have there own sepatate code that overlaps into the mechanical codes. If a code inspector quotes from the gas code pertaining to a wood stove or sloid fuel appliance I would ask for clarification in the code that applies.
We can not make up code as we seem fit there has to be some base. Now all solid fuel burning appliances use or refference NFPA 211 for compliance it now becomes fair game to apply it.
Arguing with and inspector is like wrestling with a pig in mud, after a while you realise he enjoys it
