Hello! I had a Lopi Evergreen NexGen-Hybrid Insert installed last week. It has a temperature probe going to the CAT. The manual says the CAT should not be engaged until warmed and you can tell when it is working at 500 degrees. However, I have several questions I couldn't exactly find answered on the forum:
- I burn somewhat smaller fires. Notably, once the probe reads about 350-400 degrees, I engage the CAT, and, as a result, the temp climbs to above 500 degrees within about 90 seconds. Is this an OK procedure?
- Should I disengage CAT once we are below 500 degrees? Typically, the CAT probe will reach around 700 degrees, then slowly drop to below 500 after several hours. Notwithstanding, even though the CAT is below 500, I'm still happy with the room temp, and may not add logs for a few more hours.
- Despite loss of efficiency, is it OK to run the Hybrid with CAT bypassed? Notably, the advertising material states "This advanced system drafts and operates like a super clean non-catalytic stove ..." Notwithstanding, the manual indicates the bypass is connected to both CAT and secondary burn tubes. (Note, there are some errors and contradictions in the owner's manual I noticed ... so this somewhat not reassuring)
