A lot of ash
muncybob
2,163
Near Williamsport, PA
After my 1st year of burning wood the chimney sweep stated that the elbow in my outside wall was over 1/2 blocked by a large amount of ash. At the time I attributed this to burning less than ideal wood although the stuff he pulled out was almost entirely ash and not creasote. He completed the cleaning and suggested I pull the pipe out of the elbow in the bottom of the chimney and lean it around mid season...which I did last year around the 3rd week of January. I got some ash but nowhere near the amount he pulled out.
I'm expecting him back soon to brush the chimney and decided to pull the pipe out and see how it looked...it was about 75% blocked up by ash! I removed about a gallon's worth. This seems to be an unusual amount of buildup....Is it possible that the heavy rains we have had since winter have washed down ash from the liner into the elbow?
Did the ash feel heavily caked together, or nice and loose? Do you have a cap on the top of your liner to stop the rainfall?
Some of was damp but the majority was fairly loose. There is a cap...a wire cage about 6" tall that has the cap on top, suggested to me by the chimney guy due to burning oil too. I was very surprised to see that much esp. since I had cleaned it out in January.
Possibly that big powerfull fan is taking ash out of the boiler that would be left in with most others. My 50 watt Atmos fan is pretty wimpy compared to that 1/2 or 3/4 horse Baldor fan on yours, Randy
I've also heard of the cyclone action they work on sucking ash out of the builer.
I had thought that the drawer under the cyclone piece was meant to catch the ash. I clean that weekly and it has very fine powdery ash in it. My thought is also that the fan is sucking ash into the piping and bypassing the cyclone drawer unit somehow.
I guess I'm ging to need to come up with a very long handled scooper to remove ash from the elbow on a more frequent basis. I will need to access from the T which is about 10' away from where the ash accumulates in the elbow.
Since the piping is all SS I'll need to come up with something made out of anything other than metal?
I doubt you would need to worry about corrosion from carbon steel scraping on the SS piping. If you are concerned though you could use a SS scraper or SS rod with brass blade etc. Randy
How about sliding a shop vac hose back there? I am guessing that the ash is loose if it doesn't have time to solidify?
How is the storage building coming?
Good luck,
Bill
I put a Tee with a plug instead of an elbow coming out of my EKO 40. I can reach my hand up through the tee (about 30") and clear out the horizontal pipe from the back of the stove up to the tee. I also get quite a bit of fly ash that collects here about 1/2 way through the season. I clean the chimney from the roof every fall but the loose fly ash is the only thing seems to need cleaning. I bet the shop vac idea might work well for you.
I think the first course of action would be to see if the folks at Wood Gun can give you any guidance on the issue. They should know what is normal and what is not.
Bear in mind that any particles in the exhaust stream are more than likely going to "come out" where ever it makes a bend. You would have buildup at the elbows far before you experienced anything accumulating in the straight sections of the flue.
Good luck,
Bill
I'm not sure my vac hose will be long enough, but it's worth a shot. I'll be calling the WG people sometime today or tomorrow...just wanted to see if anybody else has had this happen.
Just got the "nailers" up this past weekend for the 3 enclosed sides. 2x8's for the roof joists are sitting in my garage for install this weekend if I don't get rained out. As soon as my daughter's bf returns from a hunting trip out west I'll be picking up the metal roofing and then it's time to fill 'er up! Pics to follow, of course. Hope to have it all done by mid October at latest. Already told my friends I'm having a Woodshed Fest soon...similar to Octoberfest but with a little manual labor involved.
