Looks like the pellet boiler has 1" feed and return lines, the existing feed and return headers are 1 1/4", and the buffer tank feed and return lines are 1 1/2". Furthermore, the buffer tank had a dhw coil inside which has 1 1/4" connections.
I think I will stick with the 1 1/4" and adapt down at the pellet boiler and up at the buffer tank. Adapt up from 3/4" house dhw piping to the 1 1/4" tank coil connection.
Should the locations of the adapters be right at the equipment? Am I using the right approach?
