I've had the magnetic thermometer ever since I've been using the Non-EPA smoke dragon for many years.
Having since replaced the smoke dragon with the PE Summit, I placed the same magnetic thermometer
on the flue pipe of this EPA stove.
My ?? is as follows. Does the thermometer display readings of cresote(black area / safe (white area) for the
Non EPA stove correspond to the actuall conditions of an EPA stove.
AN EPA stove is usually putting out less creosote at the same temp as compared with a smoke dragon stove.
Inother words a Non EPA stove typically has a higher flue temp than the stove.
The Summit EPA has a lower temp than the stove.
So maybe the black and white areas on the mag. thermo. display should be adjusted at a lower level to correspond
with the less creosote that the EPA stove gives off.
any thoughts about this.
not sure if I explained it correctly, but I was just thinking about this when watching and warming up
to the summit stove following another session of snow shoveling/blowing from this to long of a winter now.
-gary
-gary
