AC-3000 Vent kit
PennPellet
45
Pennsylvania
The Harman take off fits in the void between the double wall pipe and an adapter is not needed if you fill the pipe with silicone. That vent kit is consumer grade, requires 3 screws at each joint with silicone, not enough venting to do a corner install and not a length of any venting to go through a wall thicker than a 2x4. Cheap venting, will get the job done. Will rust out and fall apart over time. but will get you up and running for cheap.
All three are Duravent. Since when is it cheap venting?
And since when did Duravent make pellet pipe that requires screws?
Please post anything from Duravent where they require fasteners. Really, I need to know this stuff. Never seen anything from them but twist-lock.
Not duravent but NFPA 211, anything without welded seams must be secured with fasteners
Nope.
