Until it melts! I'd opt for C4 to really get a boost in heat.More fuel + more air = more heat.
If you're using short pellets and you have one year of usage experience under your belt/apronI like the c4 idea but migh be a little messy. Yes the stove us set and running right pipes are free an clean of ash. I burn short pellets the burn better. The equation of more fuel + more air= heat will help me adjust fan. This is the 2nd year I've used a pellet stove so your help is most appreciated.
You should be able to get some decent heat out of that. I am not familiar at all with your stove but there are people here that are and should be able to help you with settings. Familiarize yourself with the manual and your stoves functions so when they offer advice it makes some sense to you. There are adjustments where you can get things set certain ways for the best results.It's input btu is 48,000
Adjust the stove per the manual and that's how much heat you're going to get if you've kept it clean. Like others said, try different brands but they are all basically the same btu/lb. Smaller pellet length will give more heat but you'll go through the bag quicker. Fact of life. It's rated for a certain btu/hr.
Using Premium Hardwood pellets from Orschlen's there short and burn really well. I am heating small trailer home yes we also use space heater's. I'm still learning adjustments of fan's and pellets. I will do more searches. love the help
