Air intake versus exhaust blower voltage
Brokk
126
Central/Eastern Mass
I gave up on my old PelPro 120 (2008 model) and just bought/installed a Comfortbilt HP22N. It has a nice controller that allows you to tweak many of the settings. One of them happens to be the exhaust voltage.
My Pelpro seemed to suffer from too much combustion air. This HP22N was the same way on the first start. Changing the air intake is the easiest and recommended way to reduce the combustion air. However, even with it closed as far as it is allowed, the 1/2 burned pellets are still jumping around too much IMO. So I turned the voltage down and things got better.
My question is this... Is it better to open the air intake *and* reduce voltage to get the right amount of combustion airflow, or is it better to reduce the air intake as far as possible while maintaining the highest voltage that has the right amount of airflow?
There must be some value, or balance point to how the two interact. I figure the vacuum will be much higher in the second case (high V, low air intake) and the exhaust fan will be working much harder. Not sure if that is the best scenario. (no, I haven't hooked up my gauge for the pressure yet)
If the combustion blower has a shaded pole motor (99% do), you aren't reducing the voltage, you are chopping the dwell time via the Triac and the circuitry. How they work.
(shrug)
I'm using the terminology they use in the manual and menu settings. Interpret it how you will. The effect of lowering the pull of the exhaust blower still happens. Either way, my question still stands.
Assuming one achieves the desired airflow for the flames/burn, is it better to have less voltage and more air intake, or more voltage and less air intake?
I would set it so you don’t have to keep changing the damper when changing heat ranges. So you can let the stove remain automated, keeping optimal air flow at all settings. So it sounds like you set it well.
But if you need to vary the damper because you need more range than the controls offer, then do that, it’s always better to have an optimal burn. I have to do that on mine.
Running the blower on full and throttling the damper instead seems to give more control in iffy conditions. Like if strong winds sometimes blow the fire out when running on low. Otherwise I think you’re just using more energy to unnecessarily run the motor faster. But it’s probably barely noticeable.
(shrug)
All I did was tell you the principles of operation, nothing more. Don't care what the 'manual says' it's written to be generic. I will say at least you read it. Most don't.
There’s nothing wrong with the pellets bouncing in the pot after they are burned. What are your settings on stalls one through five?
Reactions: Mt Bob
blocking the air intake by %75 on my pellet stove increased the output air temperature from 110 to 150 degree without any other changes.
I have Winslow PS40. There is no dumper.
To the OP:
I've been wondering about your original question also and hoped someone could give you an answer.
My thought is that the lower the flame "velocity", the more efficient it is because the heat stays in the box as long as possible and a slower flame would spend more time at the heat exchanger, producing hotter air output. Naturally setting it too low produces a lazy flame which you don't want.
Assuming that's correct, you would want to open the air intake as wide as possible, then reduce blower voltage to until lose the bluish color coming off the pellets.
It's all about where the airflow reduction point is and where the velocity is the highest. With the air inlet closed, the high velocity point is at the air inlet gate so the differential pressure on top of the pellets and under the pellets are small. When the air inlet wide open, the high velocity point is between the top and bottom of the pellets which produces the hottest burn.
I too would like to add my two cents worth .
Think of it this way :
The exhaust blower should be sucking a stoichiometric amount of air into the combustion chamber.
(Strickly speaking stoichiometric plus 10-20 %.)
You can do this by adjusting the blower or the damper or both as you have noted.
There are two variables which will change this setting :
A - the pellet flow : more pellets means more air . ( linear correlation )
B - the clogging up factor : as the stove needs cleaning the flow will be reduced so you need to open the damper.
As I abhor cleaning my stove I would wait until it needs cleaning and set the damper to 25% blocking and then adjust the blower. This way I might add a day or two to the cleaning cycle.
To the OP:
The enormous drag is designed to blow away the ash from the burning cup. I rather get the same amount of heat using %30 less pellets and clean the cup every 24 hours. Restricting partially the air intake or lowering the blower voltage have the same effect.
