hello
i want a wood burning fireplace in my unheated basement. this would be for supplemental heat = mancave hanging out on the weekends.
what i am very concerned with = when the fireplace is not running, how to i seal the flue so that no cold outside air is leaking into my basement ?
the flue would be metal pipes that would go out through a block wall and up the side of a 1 1/2 story house.
thanx
thanx
. Some people expect to heat a house with a basement stove and that turns out to be problematic because so much heat goes right into the ground since concrete has no insulating value, but as a man cave thing and supplement, it sounds nice. I'll let others tackle the flue question. Not sure why you would need to put out a stove fire. Once the fire is calmed down and not in danger of overfiring or backpuffing or anything, I don't see why you can't just let it die on it's own. If you're worried about leaving it unattended, many people load up their stoves, turn it down and go to work for 8 or 9 hours and come back to enough coals to start up again. Or to bed. Not that I blame you for being cautious, however...
